Go Back   RCCrawler Forums > Scale Rigs General Tech > Large Scale Rigs
Thread: I am new and need help with jeep build
Old 09-13-2016, 12:38 PM   #1
Default I am new and need help with jeep build
I love these 1/6 jeeps , I have been watching YouTube and this forum for a while. I have gotten a lot of good ideas and info here. I got a dragon jeep because of the detail. I think I will use crawler king axles, but I am not sure what is the best (strongest) transfer case and transmission for this build, as it will have a metal frame instead of plastic, so it will be on the heavier side, and I don't want to break drive line parts, (can you say bulletproof). So I was hoping you guys that have already built a jeep could give me some ideas on what you have found to be the best drive line parts, (so many choices).
PS, I will post pics
longroof is offline   Reply With Quote
Old 09-13-2016, 12:46 PM   #2
Default Re: I am new and need help with jeep build
I think it depends on what motor you thinking of running, just keep in mind the Dragon will not hold up as the Hasbro, the plastic of the Dragon isnt flexible, so I think you should use a slow motor, if you take this route axial transfer cases are ok. Just get steel gears for them and a motor above 55t as this is heavy rig if you use a metal frame custom made.
STRAT is offline   Reply With Quote
Old 09-13-2016, 02:35 PM   #3
There's a few good choices, the Axial transmission used as a T-case like mentioned above is strong. I've been beating on a disruptor T1 for a while with my heavy jeep without a single issue.
BigSki is offline   Reply With Quote
Old 09-13-2016, 07:12 PM   #4
Thanks guys
Started on the frame today, cutting out pieces, this is going to be a challenge ! Was looking at the disruptor and the Axial or maybe a RC4WD R2, I want to put the motor and trans under the hood with a transfer case under the floor, more like the original set-up. It will be a crawler, so I'm looking for torque with moderate speed
Old 09-13-2016, 07:49 PM   #5
Check out the Sticky at the top of the section, by Zoso, it'll give you some basic ideas, the rest you should be able to pick up from thumbing through the various builds in this section, Jeeps that are similar to yours.
Feel free to ask questions, most of us will help you along, and critique you if necessary , and most of all, have fun! and post lots of pics
Mike Flea is offline   Reply With Quote
Old 09-14-2016, 07:38 AM   #6
Thanks Mike Flea, Zoso's drive train has everything I was considering using for my build, only difference will be the frame. I am going to replicate the dragon frame in steel, why ? because I can !
Old 09-14-2016, 09:07 PM   #7
Everyone on here will chime in with the same advice in regards to the R2- don't waste your time or money. Those gear boxes were never designed to hold up to the weight of these large scale builds. I went through a few before I swapped in a bone stock AX-10 trans under the hood, complete with plastic gears and no slipper clutch. ( O.G. AX-10 !) Never had a single issue with that trans.
Old 09-14-2016, 10:44 PM   #8
I bought a used R2 on here reasonable and bought the rebuild kit that comes with new gears
So now its like a brand new R2, what I like about is that you can change the output
By changing the number of teeth on the pinion gear, it will change the output ratio
I'm going to try a 4 to 1 ratio with 8 or 9 tooth, 32 tooth pitch pinion
Need to look at the input and output chart again to get the ratio I want
Not sure if I'm going to use the R2
Cause I could make 2 motor forward mounts and use SCX10 transmissions
Depends on the space under hoods on the Jeeps, cause there similiar body styles, but the underhood area's are different, I might need the R2, if not I will use SCX10 transmissions
I have both, a 6th scale Dragon Jeep and My 21st Century 6th scale Jeep Mutt, that I started
My first 6th scale build was a 21st Century Humvee and I used a Wraith transmission and skid plate and the AR60 axles
And made the chassis similiar to a SCX10, with shock loops on the chassis and kept it simple with out a motor forward plate and transfer case
Cause of the front of the Humvee body, a motor forward setup would not work
kgb424 is offline   Reply With Quote
Old 10-14-2016, 11:09 AM   #9
starting to build frameName:  001.jpg
Old 11-04-2016, 09:56 AM   #10
Big Mike's Avatar
Axial SCX10 trans with Robinson Racing steel gears, Disruptor transfer case, MIP driveshafts. Powered by an old 10t Cobalt Puller from Holmes, I get excellent low speed control and enough torque and power to run faster than I can and pull big wheelies if the traction is there. Best-of-both-worlds motor. The only problems I encounter are occasionally twisting my homemade axles and the transfer case working loose if I don't check it once in a while.
I'd use a Robinson-stuffed Axial trans over the R2 any day. Smaller size and waaaay tougher. Just my .02
Big Mike is offline   Reply With Quote
Old 11-05-2016, 06:23 PM   #11
Yes Mike you are right, I have decided to use that trans, after reading more posts on these transmissions. thanks for the advise.
Old 11-05-2016, 08:40 PM   #12
Is that tube steel ?
what are the OD/ID dimensions ?
square and rectangular ?
wall thickness ?
where is it found ?
got a link ?
I googled... but seem to come up short
TacoCrawler is offline   Reply With Quote
I am new and need help with jeep build - Similar Threads
Jeep scaler build and comp micro crawler build droopmodmrc Losi Micro-Rock Crawler 1 12-25-2012 12:34 PM
Jeep TJ build MaxxZilla 1.9 Scale Rigs 1 12-02-2010 11:21 PM
New Jeep build TXJeeper1 1.9 Scale Rigs 1 05-12-2010 11:24 PM
another jeep tj build (and my first build thread) scorpion/king 2.2 Scale Rigs 5 12-18-2009 02:04 PM
