04-25-2022, 07:06 AM | #1 |
Newbie Join Date: Apr 2022 Location: Greensboro
| Multi channel remote
Hey guys so going back and forth with my designer I’m at like 26 channels I know the spektrum 20 has an add on module to make it 28 channels but that’s gonna be $3000 plus tax has anyone custom made one before I’m pretty good at soldering and half bad at vb.net programming. I know I can buy 4 function joysticks just not sure what all is needed or even if it’s possible Thanks #wayinovermyhead Sent from my iPhone using Tapatalk |
04-25-2022, 08:02 AM | #2 |
| Re: Multi channel remote
26 channels on a crawler now thats impresive weres the build ? |
04-25-2022, 09:00 AM | #3 |
It’s my heavy wrecker that’s being designed not a crawler but you guys are the only knowledgeable ones out here Sent from my iPhone using Tapatalk |
04-25-2022, 10:17 AM | #4 |
Pebble Pounder Join Date: Dec 2019 Location: East Tennessee
I know the drone/FPV gear can often have a lot of channels. I wonder if, on your build, is it possible that some channels can be combined using some sort or controller, and then the controller uses a single channel? FlySky makes a 14 channel radio called the Paladin. It might be possible to bind 2 receivers simultaneously, if that would work. It is far less than the $3000 Spektrum setup.
04-25-2022, 12:44 PM | #5 | |
| Re: Multi channel remote Quote:
That would be great if I could figure that out cause like I have 4 stabilizers that’s 4 channels but if I could combine them then that would be 1 channel Sent from my iPhone using Tapatalk | |
04-26-2022, 08:03 AM | #6 |
i couldent even imagine 26 fuctions to use a remote for but i guess when your controling 4 outriggers independently which you kinda need to be able.too i could see.how the channels could add up contact hayok on this forum thats his area of expertise ill bet if nothing else he will have some good ideas also holms hobbies he might have some ideas also maybe losikid i think is his screen name he had something to do with the flysky gt3 hack that gave it 8 channels instead of just 3 there are some realy good resorces here but most of the users with the knowledge arent reguler users any more so you might need to hunt them down |
04-26-2022, 03:27 PM | #7 | |
Lights sound steering outriggers spades wheel lift crane rotation crane extension crane lift winches Sent from my iPhone using Tapatalk | |
Multi channel remote - Similar Threads | ||||
Multi channel radio | prondzy | Newbie General | 22 | 03-30-2018 06:36 AM |
Single channel / multi-bank LED controllers? | cyrusd | Electronics | 3 | 11-26-2011 08:24 AM |
3 channel am radio, with multi model memory? | junkman | Electronics | 0 | 11-30-2009 03:16 PM |
Multi Channel Radio for your crawler | kwkride | Nebraska | 4 | 04-02-2008 11:46 AM |
