Go Back   RCCrawler Forums > Vendors > Locked Up RC
Thread: NEW - SCX10 Knuckles, Clockable C Hubs & Oversize Bushings
Old 10-23-2015, 03:21 PM   #1
SCALE PERFORMANCE PARTS
Locked Up's Avatar
Default NEW - SCX10 Knuckles, Clockable C Hubs & Oversize Bushings
No available are our High Steer Zero Ackermann Knuckles, Clockable C Hubs and Oversize Bushing set, for SCX10/AX10s.
Our knuckles help move your tie rod and drag link up closer to your chassis and out of the rocks.
This give you a better approach which helps you to avoid more obstacles in most cases.
They are also zero ackermann which means you will be able to dial in 100% steering throw to both sides.
The Clockable C Hubs are, well, .... clockable to give you 12.5* of additional caster.
The aluminum construction means they will out last your stock plastic parts and they are a great combination when used with the above knuckles.
To go with our knuckles and c hubs, we are also offering oversize bushings.
Your stock bushings will work just fine with our setup, but if you are looking for the usual, tight, LURC fit, these bushings will remove all of the play commonly found when using the stock flange pipe bushings.
Here is everything shown together...
Thanks for reading!
Locked Up is offline   Reply With Quote
Old 10-23-2015, 04:34 PM   #2
Default Re: NEW - SCX10 Knuckles, Clockable C Hubs & Oversize Bushings
Max steering angle?
alpine4x4 is offline   Reply With Quote
Old 10-23-2015, 07:09 PM   #3
Originally Posted by alpine4x4 View Post
Max steering angle?
I'm sure the max steering angle of any setup using these knuckles will be the max angle of the driveshafts.
svt923 is offline   Reply With Quote
Old 10-23-2015, 08:06 PM   #4
Nice. LURC continues to offer more awesome products. I'm getting my order in!
Killa-Cotton is offline   Reply With Quote
Old 10-23-2015, 08:15 PM   #5
I would assume so too, but ya never know!
I really dig the adjustable C's, about time someone made some for the SCX axles.
Old 10-23-2015, 08:53 PM   #6
HR already make them. lol
fr8cture is offline   Reply With Quote
Old 10-23-2015, 09:21 PM   #7
Apparently I havent been paying attention
Old 10-24-2015, 01:34 PM   #8
Locked Up's Avatar
Max steering angle?
As others pointed out ... well beyond the angle of any CVD/dog bone.
Old 10-24-2015, 06:36 PM   #9
Patrick.........You the man It's true I'm a dedicated LURC FanBoy (Man) for good reason. LURC produces my favorite scale products and have the best customer service in the industry. I don't need the new knuckles, C's, and bushing's currently but I will sale my vanquish setup so I will.
Bananaclip is offline   Reply With Quote
Old 11-04-2015, 11:56 AM   #10
R2j
SORRCA Committee Member
R2j's Avatar
Got my C's and knuckles installed! Perfect fit! Quality is bar none, great job Patrick. Still need to put the brass bushing in. Also pictured is the panhard axle mount and three link truss from the LURC Pro CMS kit.
R2j is offline   Reply With Quote
Old 11-08-2015, 01:52 PM   #11
I can't hold off any longer. I want the entire combo. Bushings,chub's,knuckles. Get ready to receive more of my money Patrick. Can I just start a running tab?
Old 11-17-2015, 05:17 PM   #12
Locked Up's Avatar
Couple of pics as requested of the fitment between the knuckle & a beadlock (Axial 1.9 with a LURC narrow hex & LURC inner ring):
NEW - SCX10 Knuckles, Clockable C Hubs & Oversize Bushings - Similar Threads
SCX10 knuckles & C hubs tokdl Axial SCX-10 27 03-03-2014 09:40 AM
You may edit your posts
