03-10-2016, 08:46 PM | #1 |
SCALE PERFORMANCE PARTS Join Date: Oct 2007 Location: Cedar Park
| A08 Our AO8™ wheels are our most scale wheel yet! AO8™ (8 Lug) These wheels feature a tighter 8 lug pattern for more "face". This means more detail and a better look on each design: Since the flanges are detachable ... you now get the option to play with track width: We even designed new M2 "Mag" Acorns to drop a scale bomb on everyone! Every AO8™ wheel is also Easy Mountฎ compatible so your foam and tire changes are a snap! Stay tuned for new designs and color options soon ... and thanks for reading. Last edited by Locked Up; 03-11-2016 at 05:31 PM. |
03-10-2016, 09:18 PM | #2 |
Rock Crawler Join Date: Mar 2015 Location: "Crawling Heaven"
| Ao8
How much per set, and what measurements do you use on the detachable hubs? __________________________ 1.9 Ibex tuber - The Merica ibex. R.I.P Dave Mirra |
03-11-2016, 09:13 AM | #3 | |
| Re: Ao8 Quote:
AO8 (8 Lug) And they work with our easy mount rings: LURC Compatible We will have a complete packager deal up (like we do for the 8L & SLW styles) soon as well. For the hub measurements, offset. backspace, etc, you can get a wealth of information here (AO8 near the bottom of post #1): Offset & Backspace Tutorial | |
03-11-2016, 01:34 PM | #4 |
| Re: A08
Cool guys thanks __________________________ 1.9 Ibex tuber - The Merica ibex. R.I.P Dave Mirra |
03-11-2016, 02:42 PM | #5 |
| Re: A08
Forgot to ask any plans for .185 hub?
03-11-2016, 03:45 PM | #6 |
| Re: A08 SLW and AO8 use different numbering systems. So adding an SLW number to our AO8 system would be confusing for everyone. Having said that... An AO8 with a 285 axle flange will offer the same track width as one of our SLW compatible wheels with a .185 hub: |
03-11-2016, 04:59 PM | #7 |
| Re: A08
Any plans on making slw versions of those acorn nuts?
03-11-2016, 05:27 PM | #8 |
| Re: A08 Nothing planned right now. Because of the scale of the bolt pattern on our SLW and our 8L wheels, they actually look better with the larger acorns. Adding a smaller acorn makes them look very spaced out .... like toothpicks on the wheel. I'd take a picture of an SLW style wheel with mag acorns to show you but they slip through the 4-40 holes. So you can imagine how wide the base on the acorn would have to be to hold it on ... which would be a weak point as well. On the 8L they are passable, but the standard acorns still look better on there. |
03-11-2016, 05:33 PM | #9 |
| Re: A08
Makes sense. Didn't realize they were that much smaller.
03-12-2016, 08:18 AM | #10 |
Quarry Creeper Join Date: Apr 2008 Location: Hiding the bodies
| Re: A08 Looks like the ideal candidate for 1.55 or 1.7 treatment.
03-12-2016, 10:06 AM | #11 |
| Re: A08 |
03-12-2016, 08:43 PM | #12 |
| Re: A08 |
03-14-2016, 11:30 AM | #13 |
| Re: A08 We have been working on the A08™ since before we unleashed the Ultra Hubs, which is why they are a perfect fit for them. I've had the finished Mag acorns sitting here since October ... of 2014. For the smaller wheels we are still finalizing a few things but I think they will be a really nice offering. The catch right now is that we are still out of a lot of our standard things due to the usual seasonal rush. So they are still a ways off because we can't even get to them! Once I have a finalized prototype though ... then I'll really tease! Last edited by Locked Up; 03-17-2016 at 07:54 PM. |
03-15-2016, 07:44 PM | #14 |
| Re: A08 |
