10-05-2016, 02:46 PM | #1 |
SCALE PERFORMANCE PARTS Join Date: Oct 2007 Location: Cedar Park
| SCX10 II - OT Shafts! Now available are our fantastic OT Shafts for the Axial SCX10 II Like the SCX10 shafts before these, they offer several benefits: 1. Torsional tensile strength rating of over 160in/lbs*. That is over 33% more than a typical stock shaft, which suffers destruction in the 120in/lb range. 2. We thread the end of the shaft several extra turns vs stock. So if you are trying to narrow up your rig with narrow hex hubs and our .185 SLW hubs you can run them with less or no washers behind your wheel nuts. 3. No "hat" near the tangs to more easily pass through axle tubes and past mounting hardware (like Gunnar tubes and CMS kit hardware). 4. A slightly thicker "tang" for a tighter fit, even with a stock locker. Even with these improvements these are a direct replacement requiring little to no modifications to a stock vehicle. You can expect a direct slide in fit with stock lockers. Thanks for reading! |
SCX10 II - OT Shafts! - Similar Threads | ||||
scx10 drive shafts | demonut | Axial SCX-10 | 4 | 05-23-2012 05:46 PM |
