Go Back   RCCrawler Forums > Vendors > Locked Up RC
Thread: 7mm wide wheel hexes
Old 11-24-2017, 02:33 PM   #1
SCALE PERFORMANCE PARTS
Locked Up's Avatar
Default 7mm wide wheel hexes
For those of you looking to gain a slightly wider stance, we are happy to now offer our 7mm wide wheel hexes.
Aluminum Hex Hub 7mm12mm Black (4)
Our 12mm x 7mm wide clamp on Aluminum Hex Hubs will work with most 1:10 scale RCs and offer backspacing similar to other 7mm wide hexes.
This version clamps onto your axle which prevents it from falling off during wheel changes.
These wheel hexes can accommodate hex pins up to 2x10mm.
FEATURES:
4-5mm step center hole (most standard 1:10 size)
12mm wide across the flats
7mm tall
Aluminum construction
Black anodized finish
INCLUDES:
Four aluminum hex hubs
Four clamp screws
Four pins
Thanks for reading!
Locked Up is offline   Reply With Quote
7mm wide wheel hexes - Similar Threads
Thin 7mm socket for hub/wheel nut? GTSLOW Tools, and Procedures 19 09-25-2015 08:04 PM
Wide Wheel Hexes? Blazerbogger General Crawlers 4 12-17-2010 11:49 PM
You may edit your posts
