11-24-2017, 02:38 PM | #1 |
SCALE PERFORMANCE PARTS Join Date: Oct 2007 Location: Cedar Park
| 1.75mm HD Socket Driver Our tool tips are specifically designed to install the Scale Hex Bolts we offer as options for our bead lock wheels & rings. This 1.75mm version is perfect for the 1-64 hardware used on our 1.55" wheels. This HD version is made from a similar material to our FI Spool to be able to tackle the toughest jobs. The shafts are 3mm in diameter and work great in LURC Tool Handles, variable speed electric drivers and will slide right in to most RC driver handles. Specifications Hex: 1.75mm Shaft Diameter: 3mm Length: 90mm Material: HD Steel Each order includes 1 tool tip. Thanks for reading! Last edited by Locked Up; 11-25-2017 at 11:01 AM. |
1.75mm HD Socket Driver - Similar Threads | ||||
socket driver | speedytobey | Axial SCX10 II | 1 | 08-15-2016 12:45 PM |
New 3mm Extended Socket Driver | Locked Up | Locked Up RC | 0 | 06-17-2015 12:13 PM |
What Socket Driver Are You Using on VPs? | Knarly Nerd | Tires and Wheels | 18 | 02-19-2012 09:49 PM |
