12-01-2009, 01:45 AM | #1 |
Quarry Creeper Join Date: Jun 2009 Location: Minnesota
| Any must does right out of the box??
Just curious if there is any "Must Do's" to the micro crawler out of the box? Ive seen alot of people move the esc around, etc.. So what are the "Must Do's"?
12-01-2009, 01:51 AM | #2 |
Who's your Daddy-0! Join Date: Mar 2008 Location: Augusta
Change that thread title! "Must Do's, not Must Does!" Drop the suspension down! Cut the springs or run droop. Move the battery to on top of the servo. Trim the body to fit as low as it can on the chassis. Start there and have fun! |
12-01-2009, 08:27 AM | #3 |
Rock Crawler Join Date: Nov 2005 Location: Rock-throwing country
and buy the lipo |
12-02-2009, 04:31 AM | #4 | |
Thanks for the tips. | |
12-02-2009, 02:59 PM | #5 |
Quarry Creeper Join Date: Dec 2008 Location: Post Falls, ID
How about removing foams and putting in bbs?
12-02-2009, 03:14 PM | #6 |
Quarry Creeper Join Date: Apr 2008 Location: Racine
I left the foams in and was able to get 20 BBs in easily. After running it that way today, I'd say it's a must do.
12-02-2009, 03:25 PM | #7 |
Pebble Pounder Join Date: Sep 2009 Location: Alabama
This is what I did to mine put a lipo on the rear axle flipped the tranny flipped the esc and esc mounts around run droop shocks The body is sooo light I don't think it will matter much. |
12-02-2009, 03:56 PM | #8 |
Rock Crawler Join Date: Apr 2008 Location: Greentown
the body will make a difference, light or not. drop it low, and make her slow.
12-02-2009, 04:00 PM | #9 | |
do the bbs roll around or get bunched up in one spot? i would worry about them all getting stuck at the top of the tire and hurting things. anyone pulled the foams and found them to run ok? So far I have only stuck a wheel weight next to the nut with some tape, just for performance, looks arent good just yet until i figure out what ima do with the tires.... afraid to glue them and remove as they are so small to begin with, dont want to hurt the looks of the thing. | |
12-02-2009, 04:03 PM | #10 |
Rock Crawler Join Date: Dec 2005 Location: Tulsa, Oklahoma
Pull the tires off and wrap solder around the wheel, works alot better than the BBs. Move the battery to the rear axle flip the Trans/ESC Not a must, but: Soft White Micro-T springs 2S LiPo Last edited by Shaun; 12-02-2009 at 04:12 PM. |
12-02-2009, 05:18 PM | #11 |
So far I removed the foams (I didnt have any bb's... nephew used them all ) mounted the esc on the servo and the battery on the rear mount. Seemed to help alot. When dropping the body, I assume you need to trim off the body that hangs low? Or does it still clear? I cant wait until they make aftermarket bodies for these. I hate the stock ones. |
12-02-2009, 09:02 PM | #12 |
Quarry Creeper Join Date: Oct 2009 Location: northeast ohio
What lipo are you guys getting? Can you post a link for a good one thanks |
12-02-2009, 10:56 PM | #13 | |
Link to the Thunderpower http://www.horizonhobby.com/Products...D=THP3502SJPL2 | |
12-02-2009, 11:03 PM | #14 |
| http://www.aero-nuts.com/product_inf...roducts_id=602 200mAh plenty, I would order at least three for yourself and maybe a few to sell to freinds or for christmas gifts! |
12-04-2009, 04:31 AM | #15 |
My buddy just got the Losi 180mah 2c and is getting 20 minute run times! I forgot to ask how long it took to charge though. I heard it over the phone and it sounded like a electric chain saw..lol.
12-05-2009, 01:17 PM | #16 |
Quarry Creeper Join Date: Feb 2009 Location: Houston
When you guys are talking about flipping the Tranny, would swapping the axles create the same effect?
12-05-2009, 07:34 PM | #17 | |
Just thinking. Someone should put a small spring between the two drive lines. Front and rear. What would happen? | |
12-05-2009, 07:43 PM | #18 |
12-08-2009, 06:33 PM | #19 |
Quarry Creeper Join Date: Jun 2004 Location: Fairmont
What exactly does flipping the Tranny accomplish? Just wondering, since you all are talking about it.
12-08-2009, 06:36 PM | #20 |
Newbie Join Date: Nov 2009 Location: Roy
