Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Heritage Crawlers > Losi Micro-Rock Crawler
Thread: BBs in the tires.....
Old 12-10-2009, 10:52 AM   #1
Default BBs in the tires.....
Ok, so I went to but some BBs in the tires, took the foam out and put 30 BBs in. Now I cant get the tire the stay between the rim and the lock.
Did you guys that did this glue them back on? Or did the locks work?
dougie fresh is offline   Reply With Quote
Old 12-10-2009, 11:12 AM   #2
They are not functional beadlocks.
tjscrogins99 is offline   Reply With Quote
Old 12-10-2009, 11:21 AM   #3
Yeah, they're fake beadlocks. The tires come pre-glued and if you take them off the rim you need to re-glue it back on. I removed one side of the tire and flipped it inside out to get access, that way I had half as much gluing to do after.
AdverseCity is offline   Reply With Quote
Old 12-10-2009, 11:44 AM   #4
Sounds good guys, thanks, will super-glue do the trick?
Old 12-10-2009, 11:49 AM   #5
Any CA, super glue included will do the trick
DickyT is offline   Reply With Quote
