12-10-2009, 10:52 AM | #1 |
Newbie Join Date: Mar 2009 Location: lamar
| BBs in the tires.....
Ok, so I went to but some BBs in the tires, took the foam out and put 30 BBs in. Now I cant get the tire the stay between the rim and the lock. Did you guys that did this glue them back on? Or did the locks work? |
12-10-2009, 11:12 AM | #2 |
Pebble Pounder Join Date: Apr 2007 Location: Columbus
They are not functional beadlocks.
12-10-2009, 11:21 AM | #3 |
Rock Crawler Join Date: Jan 2008 Location: Calgary Crawlers, Alberta, Canada
Yeah, they're fake beadlocks. The tires come pre-glued and if you take them off the rim you need to re-glue it back on. I removed one side of the tire and flipped it inside out to get access, that way I had half as much gluing to do after.
12-10-2009, 11:44 AM | #4 |
Sounds good guys, thanks, will super-glue do the trick?
12-10-2009, 11:49 AM | #5 |
Any CA, super glue included will do the trick |
