12-10-2009, 07:23 AM | #1 |
Adilynsdad too! Join Date: May 2004 Location: G ville
| battery connections...
what battery connections are you running? micro deans regular deans stock other |
12-10-2009, 07:25 AM | #2 |
Stock for now. I will be converting to micro deans.
12-10-2009, 07:45 AM | #3 |
Quarry Creeper Join Date: Apr 2008 Location: dallas
micro deans here..
12-10-2009, 07:47 AM | #4 |
Rock Crawler Join Date: Apr 2008 Location: Wrightsville, PA
micro deans
12-10-2009, 08:09 AM | #5 |
Quarry Creeper Join Date: Jun 2005 Location: Maryland
I just cut the side tabs of the battery so that the connector will slide into a JST connector for charging on standard charger. Works fine.
12-10-2009, 08:36 AM | #6 |
Rock Crawler Join Date: Apr 2005 Location: Humble
Micro Deans, which seem small untill you use them in a micro vehicle...LOL I pretty much replaced all the wiring, it's all way to stiff for a micro. |
12-10-2009, 08:41 AM | #7 |
I wanna be Dave Join Date: Aug 2006 Location: under a rock and a hard place
x2 on replacing the wires,way to stiff.I went to the local slot car place and am using the wires they use. Super flexable,kinda like micro noodle wire.try slot.it and look for the leads to the motors...good stuff, part # sp03 if I remember right. Micro deans are in the works when my new batts arrive, didnt want to canabolizr the ends on the current batts as they are the same ones I run in the mini |
12-10-2009, 08:51 AM | #8 |
Quarry Creeper Join Date: Dec 2005 Location: SLC
I wired my esc directly to the motor to eliminate that connector. Then i used that connector to make an adapter from stock to micro deans. Now I can run stock plugs or micro deans. I can also charge both using the adapters.
12-10-2009, 09:09 AM | #9 |
Rock Crawler Join Date: Dec 2008 Location: Marengo, Ohio
Micro deans all around, no connectors on motor leads.
12-10-2009, 09:18 AM | #10 |
micro deans |
12-10-2009, 10:47 AM | #11 |
Rock Crawler Join Date: Apr 2008 Location: SO CAL
I used poloraized micro deans, im to lazy sometimes to look at the wire colors lol
12-10-2009, 11:48 AM | #12 |
Rock Crawler Join Date: Feb 2006 Location: jacksonville beach
yeah, im going w/ micro deans. My thumbs are sore! :-P
12-10-2009, 02:02 PM | #13 |
where are you guys ordering your micro deans from?
12-10-2009, 02:04 PM | #14 |
got mine from my local LHS |
12-10-2009, 02:13 PM | #15 |
| My second job is part time at LHS, I will get them there. http://www.hobbysuperstore.com is their website.
12-11-2009, 04:48 AM | #16 |
Rock Stacker Join Date: Mar 2008 Location: meriden, ct
Anyone looking to upgrade their wires, this stuff is awesome http://www.atomicmods.com/Products/A...re__10105.aspx |
