12-23-2009, 01:44 AM | #1 |
Newbie Join Date: Mar 2007 Location: USA
| 1929 Ford pickup! Here is my micro.... the body is from a 1/24 model kit of a 1929 ford custom pickup. It is pretty narrow and had to cut out some parts to lower the body as much as possible. The model itself is a real POS, nothing really fit right and ended up having to patch up a lot of places, and used up way too much glue. But I am finally happy with how it looks and performs. The battery is inside of the hood, and the rx is removed from the case so that the truck body can fit via velcro and still have the rx on the truck. Added micro-t springs, otherwise it's all stock I did have binding in the center tranny, and did the sanding around the bearing trick that others have done here.... it's now nice and smooth. here is a video of it in action: http://www.youtube.com/watch?v=yXVo3G2HMjg I've applied a primer coat, I think I still want to paint it black, so that the holes are not as blatantly apparent, but the primer color is starting to grow on me -Crabfu |
12-23-2009, 04:28 AM | #2 |
Newbie Join Date: Apr 2008 Location: bangkok thailand
Very interesting to see such an old body on a crawler. I'm not sure if I like the rounded hotrod nose of that Ford but I love the pontoon fenders. You managed to make a crappy kit look pretty good. If it just had a regular vertical grill like the Model Ts I think it would be much cooler. Not sure if such kits exist but maybe you could just make a grill out of styrene. |
12-23-2009, 08:14 AM | #3 |
Rock Crawler Join Date: Mar 2009 Location: West of Eugene, OR
Yeah...that little snubby nose sure gives her some character. Cute in an ugly dog sort of way. I really like it, actually. An old primer-job would look good, as would a sick bling-like paint scheme. Looking forward to seeing how you decide to finish her off. |
12-23-2009, 03:28 PM | #4 |
Rock Stacker Join Date: Dec 2009 Location: Santa Cruz
you should take the springs off the shocks. will lower it and make it perform 100 times better |
12-23-2009, 03:36 PM | #5 |
I wanna be Dave Join Date: Jan 2009 Location: By a lake in Thornton
that rules. removing springs will help. i wish it could be mounted lower on the chassies. does that model kit come w/ framerails? |
12-23-2009, 03:49 PM | #6 | ||||
I was running droop without springs, but decided to put in low springs from micro-t, and it works better on the losi track than without springs. It really is almost like not having springs, it's pretty low down there. In the video you can see it clears that track pretty well, and it was a tiny bit more struggle when running with this body and without springs. I can't get the body any lower on the chassis, but it does look a little bit better without springs. However, I'd like to get it looking as good as possible while able to perform well, and this was the best that I could do At least until I get bored and take out the springs AGAIN, and probably will decide then again that's a better choice afterall lol. Anyway thanks for the comments, will try to find time to paint it up and see how it goes. -Crabfu | ||||
12-23-2009, 04:01 PM | #7 |
if you could use the model kit itself to mount the skid links and shocks, you could do away w/ the chassis side plates. then you can run your shocks fully sprung. just make the mounting point where YOU want them |
12-23-2009, 04:41 PM | #8 | |
-Crabfu | |
12-25-2009, 12:14 AM | #9 |
| Here it is painted black with a few logo stickers and with no springs. I mounted the electronics up in the cab now and servo taped the body to the frame... I had velcro before, which was easier on and off, but made it slightly higher. I can get to the switch through the windows, and battery leads are below the nose, so it's only a problem if I wanted to change the body on a regular basis.... which I just might lol. -Crabfu |
12-25-2009, 11:53 AM | #10 |
Pebble Pounder Join Date: Mar 2006 Location: Placerville
I just built that model, and although I like the idea of that as a custom body...you could have done much, much better.:-P Last edited by KnutKase; 12-25-2009 at 12:24 PM. Reason: ad pic |
12-25-2009, 12:23 PM | #11 |
12-25-2009, 12:47 PM | #12 |
I heavily customized mine, took awhile...
12-25-2009, 12:55 PM | #13 |
12-25-2009, 01:00 PM | #14 |
It is a 28-31 model "A" specifically a 29, not a model "T". Custom frame is a must, use aluminum stock. Increase wheelbase on crawler slightly. Cut off fenders. Chop cab roof, shorten bed. Add tonnau cover to bed, cut out bed floor. Trim visor/windshield brow. Enlarge rear window to reveal. Ditch the horn. Add way cool domed headlight lenses and custom tinted windows (ask me how). Use either stock radiator shell (or track nose as you did)
12-25-2009, 01:02 PM | #15 |
I'm NOT cutting up that model. But I might build another.
12-25-2009, 01:25 PM | #16 |
Lol models like this clearly is your domain, so yeah make another for the micro. I just tinker around and play, haven't done a model kit since I was a little kid, or care about it as much as hardcore model guys like you, so give me a break dude. Merry Christmas and happy holidays everyone!
12-25-2009, 01:29 PM | #17 |
Chill man, I'm trying to offer constructive critisism. I didn't intend to be mean. I build r/c vehicles the same way, attention to detail. Lots of hand-made custom parts. You had a great idea, just could have been better.
12-25-2009, 01:47 PM | #18 |
Shouldn't it be steam powered?
12-26-2009, 12:13 AM | #19 |
Lol I wouldn't call "you could have done much much better" constructive... But it's all good, we are all here to share And steam is over rated and over done already. |
12-26-2009, 04:03 PM | #20 |
You are right, I should have toned that down a notch. Sorry 'bout that.
