12-24-2009, 07:31 PM | #1 |
I wanna be Dave Join Date: May 2006 Location: Arlington, VA
| BND & Nomadio?
Anyone with a Nomadio, Sensor or React, been able to bind it to the Micro Crawler? I have a Sensor and am hoping I can use it with a BND. |
12-24-2009, 09:30 PM | #2 |
Rock Crawler Join Date: Jan 2008 Location: Calgary Crawlers, Alberta, Canada
Not sure but an easy way to find out would be to try binding your radio to any Spektrum receiver. If that works, I'm pretty sure it'd work with the micro.
12-25-2009, 05:21 PM | #3 |
Rock Stacker Join Date: Jul 2008 Location: river ridge
Not all spectrum recievers will bind to a nomadio... but yes it will bind to the nomadio as weel as the stock mrc reciever.
12-26-2009, 11:04 AM | #4 |
I wanna be Dave Join Date: Aug 2006 Location: under a rock and a hard place
X2 on the react, no problem.Tell the model to run iin beta in the original set up of that model and select beta in the opening screen when you change to that model selection. The sensor will require you to use the putor and change the radio settings over to DSM Beta mode.If you are running other cars off of the Nomadio transever, you will have to change that setting via the putor everytime you want to use the micro TX/RX unit. |
