01-02-2010, 03:49 PM | #1 |
Newbie Join Date: Mar 2009 Location: lamar
| what do i do??
I left my truck turned on with the battery in it by accident, I pluged the battery into the charger and the red light isnt coming on. What did i do? Is there a way to fix this? |
01-02-2010, 03:56 PM | #2 |
Quarry Creeper Join Date: Aug 2009 Location: Acushnet Mass near cape cod
are you using the portable charger that comes with it . if so try new batteries in it . i left mine on till stone dead with the stock battery , but never let that happen with a lipo . are you using a lipo?
01-02-2010, 04:19 PM | #3 |
Oh sorry, I should have filled that info in before I posted. I`m using the stock battery, and yes, I`m using the stock charger. The batterys in that are pretty new, they have only charged the truck battery 2 or 3 times. |
01-02-2010, 05:03 PM | #4 |
try some new batteries in the charger first . plus its not a big loss if that battery is junk .the losi lipo is a big improvement . $40 with wall charger
01-02-2010, 05:22 PM | #5 |
Hmmm, well I`ll try some new batteries. If nothing i guess I`ll go LiPo, thanks for the help.
01-02-2010, 06:59 PM | #6 |
Newbie Join Date: Nov 2007 Location: Fresno
What happened is the battery was drained completely, and the stock charger doesn't recognize it now. If you have a charger that can charge at 0.1 amps, use that and you can charge the battery up that way. The battery issue was discussed a bit here, battery help ?.
01-02-2010, 07:45 PM | #7 |
Quarry Creeper Join Date: Mar 2008 Location: Casper
I upgraded to the lipo and What a difference it made. The stock battery I thought sucked.
01-03-2010, 08:53 AM | #8 |
thanks for the link, and i do plan to get a lipo sometime soon. just isnt in the cards at the moment. but i think i figured out a little trick. the first time this happened, i freaked out, POed because i just got the thing. so out of panic i pulled the chager apart and went at it with a test light. i didnt know what i did but i touched something together, saw a little puff of smoke, and the red light came on. so, last night i went to take it a part again to see what i crossed. the board that has all the wires going in and out, has two black wires side by side. and two red ones side by side sitting next to the black wires. i touch the two red ones and boom, the light is on and the battery charges. sorry if i ran on and on about this. |
01-03-2010, 10:32 AM | #9 |
Newbie Join Date: Dec 2009 Location: Indianapolis
grab a 9v battery, plug pos to pos, neg to neg to your stock nimah battery pack for a minute to 2 minutes.. unplug than charge.. thats all you need to do.
01-03-2010, 03:18 PM | #10 |
pretty cool trick, that would be better then taking the charger apart and probley faster.
01-04-2010, 04:00 AM | #11 |
depending on how long it was left on, you may only need to do it for 30-45 sec. its just like a jump start for a car. puts enough power into the battery to be able to be recognized by the charger
01-04-2010, 03:35 PM | #12 |
I wanna be Dave Join Date: Feb 2007 Location: South FL
| THANKS! You know, I knew I just needed to jump start the battery with a low amp charger but i never thought to use a 9v I just broke apart a paperclip rather than strip some spare wire and connected to the flat contact on the plug of losi battery with of course the other ends to the 9v stood on end a few quick seconds and it worked like a charm. the portable charger pack is charging it just fine now Now i can crawl while my lipos gets here from china lol I ordered 2 from Himodel.com $4.85 300mah 2S 25c and a $2.99 300mah 1s 25c (in case i dont like the extra wheel speed ) Both have the same length and width as the losi Nimh when layed on the rear axle just a bit thicker I haven't read anything about the site so I'll make a post when the Lipos get here |
01-04-2010, 04:37 PM | #13 |
glad it worked for you and this topic is being seen by others with the same problem. its actually an old school micro tip |
01-04-2010, 07:09 PM | #14 |
RCC Addict Join Date: Jan 2009 Location: Jacksonville Illinois
| Thats funny I actually did that once last year bout this time with a micro dt battery. Like the OP I accidentally left it on and only had a stock charger at the time to charge it with. Its all Hyperion now baby(and lipo)
01-04-2010, 07:34 PM | #15 | |
Quarry Creeper Join Date: May 2006 Location: Volcano, Hawaii
01-07-2010, 07:39 AM | #16 |
Newbie Join Date: Jul 2006 Location: Bossier City
Great info guys! This will definetly help when I leave mine on. I know it will happen sometime soon. Thanks again.
01-07-2010, 11:15 AM | #17 | |
I normally keep an eye on things and dont push it but you never know | |
01-07-2010, 11:26 AM | #18 |
Quarry Creeper Join Date: Apr 2009 Location: Plainfield
Mine did that too. I jiggled it around and worked fine since.
01-07-2010, 12:19 PM | #19 |
just an FYI, this is only used with NiMAh batteries... do not do this with a lipo!
