01-03-2010, 11:14 PM | #1 |
Newbie Join Date: Jan 2010 Location: Edmonton
| Micro Losi MOD!!
I found that the servo wire was binding with the front shock body. I run my micro crawler without springs. So what I did is remove the lower servo housing and with my Dremel and a small carbide ball tool, cut a slot in bottom of the lower housing to pass the servo plug and wire thru. This set up works the best. There is no more binding between the wire and shock body or the wire and the top shock mount nut on the frame. I hope this helps you guys out. LEADHEAD |
01-04-2010, 10:51 AM | #2 |
Rock Stacker Join Date: Dec 2009 Location: Duvall, Wa
Could you post a few pictures of this?
01-04-2010, 11:29 AM | #3 |
Pebble Pounder Join Date: Sep 2009 Location: Alabama
That is a good idea. I have my servo wire taped and zip tied all over everything to keep it from rubbing.
01-04-2010, 11:47 AM | #4 |
Rock Crawler Join Date: Mar 2009 Location: West of Eugene, OR
In stock form, mine did the same... After I relocated the Rx/ESC, I was able to simply force the wire around a different way, as the tension keeps it away from any binding points. |
01-04-2010, 12:02 PM | #5 |
| Pic's
I have pic's posted on the LOSI forum. If you can't find them drop me an e-mail and I will send them your way.
01-04-2010, 01:22 PM | #6 |
RCC Addict Join Date: Sep 2007 Location: Western ND, Bakken central
Mine does the same thing, thanks for the tip |
01-04-2010, 01:29 PM | #7 |
I found your pics on Losi's forum. |
01-04-2010, 01:49 PM | #8 |
Thanks 701!! I did try and post pics last night and could not get them on here! |
01-04-2010, 04:24 PM | #9 |
Newbie Join Date: Aug 2008 Location: BC
Good thinking! thanks for posting that, alot better than the ziptie Im using.
01-05-2010, 08:21 AM | #10 |
No problem!! |
01-06-2010, 09:58 AM | #11 |
Can we move this into the mod sticky??
