01-05-2010, 07:46 PM | #1 |
Rock Crawler Join Date: Jan 2008 Location: Calgary Crawlers, Alberta, Canada
| Micro Mosi in progress
I had this killer idea and just tried it, I think it'll work quite well and figured I'd post up looking for some input. I just need to find and mount the gears for reduction and test it but I'm hopeful. This won't be possible for the front unless I can re-locate the servo, no luck finding a way to do that yet so I'll probably just leave the front shafty and MOA the rear. At least I can use an electronic dig switch this way. Anyway, on to the pictures. The 3rd picture shows where I plan on mounting the reduction gears. Any feedback, good or bad, is welcome...... |
01-05-2010, 08:20 PM | #2 |
Newbie Join Date: Apr 2008 Location: bangkok thailand
Good idea. It would be tough but maybe you could just find a low RPM/high torque motor to output directly into the axle instead of above it. You'd probably have to make a shim to fit the worm gear on the motor shaft but if you can find the right parts, then you might be able to run the steering servo still. |
01-05-2010, 11:53 PM | #3 | |
Quarry Creeper Join Date: Sep 2009 Location: Scottsdale
Love the ingenuity though. How thick is the plate you are using. | |
01-06-2010, 05:12 PM | #4 |
| It's just some delrin I had laying around, 3/32 of an inch I believe. This is just for mock up, the final version will most likely be aluminum. I also found some gears that might work, I just need to figure out how I want to mount them. This is turning out to be easier than I thought when I started but I'm sure that'll change. |
02-08-2010, 07:06 AM | #5 |
Quarry Creeper Join Date: Dec 2008 Location: Dalton
any updates? What about turning the motor around 180 and mounting it like eritex does the 1/10 LCC?
02-08-2010, 03:50 PM | #6 |
Newbie Join Date: Aug 2008 Location: TENERIFE - ISLAS CANARIAS - SPAIN
Why dont you try this one? l http://www.shop.kkpmo.com/product_in...1-Getriebe.htm Greets from Munich myrna |
02-10-2010, 01:25 AM | #7 |
Pebble Pounder Join Date: Sep 2009 Location: Michigan
I have one of those! put it in a scale hemi. now what?:?
02-10-2010, 04:17 AM | #8 |
RCC Addict Join Date: Jan 2008 Location: Lake Michigan
I have two of those going into an (non-losi) MOA rig. Mini/Micro - MOA - Scratch Build Held in with 2mm screws into the brass end plate. I stripped one already. Jumping from the 100:1 to the 150:1 versions now. Mine are from Pololu. Vegas area, fast shipping. http://www.pololu.com/catalog/category/51 They have others that are slightly bigger, not geared as low, that look planetary and are enclosed. |
02-11-2010, 10:15 AM | #9 |
Newbie Join Date: Dec 2009 Location: Canada
I don't understand why u need to change the tranny in this way. what u wanna make. It's rather messy this way.
02-11-2010, 10:50 AM | #10 | |
02-11-2010, 05:09 PM | #11 |
Pebble Pounder Join Date: Sep 2008 Location: asheville
Quick questions about the gearbox, do you use a servo motor or the micro motor that comes with the crawler, is the output shaft the same size as the mini crawlers output shaft, and are the holes used to mount the gearbox in the same place as the ones on a mini motor? I don't know if it will work for my next project, and an any info would be greatly appreciated. thanks nic |
02-12-2010, 12:15 AM | #12 |
This is a very cool project. You have to have a lot of patience to do this, especially on a vehicle so small!
