Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Heritage Crawlers > Losi Micro-Rock Crawler
Thread: Micro Ranks
Old 01-08-2010, 10:38 PM   #1
Default Micro Ranks
As in joined them! Got a black one tonight. Charging it up as we speak. Going to do some reading so I can get started modding.:-P
Duspan is offline   Reply With Quote
Old 01-09-2010, 09:13 AM   #2
These things are a blast! I got mines and so far the only thing I have done is take the springs off, though I haven't had much chance to test it that way.
Knytemare is offline   Reply With Quote
Old 01-09-2010, 11:47 AM   #3
Lipo's guys they make all the difference
88gmchog is offline   Reply With Quote
Old 01-09-2010, 06:31 PM   #4
rik
these lil guys are great. i cut 4 coils off the springs, reversed the tranny, lipo on the rear axle, and micro deans so far. that little made a huge difference! like you said, read these these threads. plenty of knowledge and sick rigs to be found!!!! have fun!!!!!!!
rik is offline   Reply With Quote
Old 01-09-2010, 08:10 PM   #5
Took the foams out and put the bat on the servo. What does cutting the springs do? I can't wait until the aftermarket gets ahold of this thing.
Old 01-09-2010, 08:12 PM   #6
cut springs = lower center of gravity, and semi droop to improve its handling on the rocks
Old 01-09-2010, 08:29 PM   #7
You will love it! So far I have:
BWD wheel weight kit
relocated battery and esc to axles
removed internal plastics
cut the original battery holder down to use as a chassis brace to reduce
flex of having taken plastics out. (coming soon BWD Wedge)
droop using mirco t rears stretched over the shock cap and ball cup as return springs, red (medium) rear and white (soft) front,
Inverted shocks lowering CoG
extended bent lower links, extended upper links
Lowered upper shock mounting point to old internal plastics mount, lower CoG
lipo
flipped tranny shifting weight forward
Hacked the body to allow droop clearance of esc on front axle.
Cut windows out of the body (weight redux?) lol just for fun.
hs-65 servo - ridiculous steering power!
DickyT is offline   Reply With Quote
