03-08-2010, 09:10 AM | #1 |
Rock Stacker Join Date: Jun 2007 Location: Abbotsford BC
| DSM vs DSM2?
I just noticed that the micro crawler says DSM on the receiver... does that mean my DX5 wont bind to it? I've been saving up to buy a BND...
03-08-2010, 11:43 AM | #2 |
Rock Stacker Join Date: Jan 2010 Location: montreal
dont know but I got a DX3R and it work fine
03-09-2010, 04:11 PM | #3 |
03-09-2010, 04:18 PM | #4 |
Rock Stacker Join Date: Jan 2007 Location: Elk Grove
I believe there's a difference between surface and air TXs and RXs. They don't mix.
03-10-2010, 02:53 AM | #5 |
Rock Stacker Join Date: Feb 2010 Location: QUEBEC canada
| sorry but it won't work.... :(
i already tinking use a dx5 but that don't work you need the 5 ch receiver and a news esc... the rtr is only 25$ = than the bnd...
03-10-2010, 05:45 PM | #6 |
Quarry Creeper Join Date: Dec 2009 Location: Long Island
DSM and DSM2 Don't correspond with eachother. I have seen some use a DX6i in say an SC10 or whatever(not SCX10 but SC10) just an example, but they had to use the air rx also. You're best bet would be to go RTR. DSM and DSM2 don't run on the same..you know...I can't exactly word it.
03-10-2010, 08:16 PM | #7 |
Pebble Pounder Join Date: May 2009 Location: ashland
Actually DSM2 transmitter will work with a DSM reciever but not the other way around.
03-10-2010, 08:24 PM | #8 | |
Rock Stacker Join Date: Dec 2009 Location: O.C.
The mcx/msr conroller which is dsm2 will not bind with the micro crawler. And I'm pretty sure I read in the Horizon catalog that the new spectrum controllers would bind to the dsm2 receivers. I'm not 100% this is just my 2 cents. Last edited by Helihover; 03-10-2010 at 08:28 PM. | |
03-10-2010, 08:24 PM | #9 |
| Thanks for clarifying. I knew the DSM transmitter wouldn't work with the DSM2 RX but wasn't too sure on the other way around. I've seen people run DX7's DX6i's and DX5e's on their surface vehicles btw..
03-10-2010, 08:29 PM | #10 |
Rock Stacker Join Date: Nov 2006 Location: 1/2 way between Cleveland and Columbus
I use BR6000 receivers with my DX6 for my scalers. The BR6000 is a bot receiver and the AR6000 is an air receiver. I believe the only difference is the fail safe mode. I think the bot shuts everything down whereas the air receiver will maintain the last input. Something like that, not exactly sure. I don't believe it is possible to bind a radio with a receiver that doesn't have the same number of channels.
03-11-2010, 07:15 AM | #11 |
03-11-2010, 07:18 AM | #12 |
To use an air radio, you have to use an air receiver. And yes, DSM2 surface radios will bind with most DSM surface receivers.
03-11-2010, 08:46 AM | #13 |
Pebble Pounder Join Date: Feb 2010 Location: Nassau, NY
