09-20-2010, 06:17 PM | #1 |
Quarry Creeper Join Date: Mar 2007 Location: Martins Ferry,OH
| What do u think of this idea?
ok well my idea is making a tuber out of a hanger and making it look like the stock body???
09-20-2010, 06:37 PM | #2 |
RCC Addict Join Date: Oct 2009 Location: In the mancave...
ya know, some will say yes, and some will say no...but rik always says screw and give it a try, cus ya just never know..... definitely post pics if ya do it. sounds interesting. |
09-20-2010, 07:36 PM | #3 |
Yah I'm gonna try to do it I'll post pics as I go tomorrow around 4:30 est.
09-20-2010, 08:52 PM | #4 |
I wanna be Dave Join Date: Jan 2008 Location: GrandRapids, MILITIAGAN
Do it. I mean how many hanger do you have in you closet. I have like 40, so its worth a try. If it dosent work your only out a hanger.
09-21-2010, 12:03 AM | #5 |
Rock Crawler Join Date: Mar 2008 Location: Grand Rapids
if its gonna be structural i'd go with something a bit stronger than a brass or copper coat hanger maybe some small steel rod
09-21-2010, 03:36 AM | #6 |
i think its strong enought to hold the rig for a small flip i dont plan on letting it roll down something
09-21-2010, 07:59 AM | #7 |
Quarry Creeper Join Date: Apr 2010 Location: Southern Aroostook County
I was just fooling around with coat hangers a couple nights ago.. pretty close to a scale tube for this rig, makes for a good solid joint when joined with harris 56 silver solder. I made a bumper for my Slamurai project but i wasnt too happy with the design so I scrapped it... |
09-21-2010, 08:28 AM | #8 |
09-21-2010, 02:15 PM | #9 |
Haven't decided what's logical
09-21-2010, 03:18 PM | #10 |
Probly gonna start this on the weekend I need better solder and a hotter gas
09-22-2010, 09:39 AM | #11 |
use a mig welder it'll make quick work of it just turn the voltage all the way down
09-22-2010, 01:40 PM | #12 |
A mig will warp coat hanger solder is nice for making a tuber. You want small tacks. And we all know that you cant control or modify a oversized mig tack on something sooooo small. You can file extra solder down, instead of grind.
09-22-2010, 02:30 PM | #13 |
RCC Addict Join Date: Jun 2007 Location: MESA
To be honest I think a mig is a bad idea. I have been welding for years and have built a few tubers on here out of brake line. I actually used to use coat hangers as filler metal when doing oxy-accetelyne welding. I have a small map gas / oxy set-up at home and tried just heating the coat hanger material together...it works well. After the rig is built it wouldn't hurt to go over the joints with solder but good luck soldering onto something that melts at almost the same temperature. I am building a coat hanger tuber now and it looks like the map gas / oxy set-up is going to work great. as I heat up the pieces just to the melting point and then remove the heat, the two pieces join together with descent strength. just my opinion There are many ways to get it done. I will post some pics soon to show my method of madness. |
09-22-2010, 02:42 PM | #14 |
when i mentioned a mig i was referring to using steel rod as i had mentioned before seriously i dont know if anyone is dumb/ballsy enough to try to weld coathangers together with a mig
09-22-2010, 02:51 PM | #15 |
09-22-2010, 03:08 PM | #16 |
read the thread ...now youre just posting just to post
09-22-2010, 03:31 PM | #17 |
Wire out of a mig as a chassis.WHAT!
09-22-2010, 03:33 PM | #18 |
09-22-2010, 03:53 PM | #19 |
IMO even the coat hanger material is a little small for the micro. Scale wise it looks like u r running 1" tubing for a frame or cage. It's good enough and easy to work with but still not perfect. I hope it WAS a joke to run mig wire Although I would love to watch a video of someone trying |
09-22-2010, 05:17 PM | #20 |
Not just any mig wire, .35 mig wire |
