10-01-2010, 03:25 PM | #1 |
Quarry Creeper Join Date: Mar 2007 Location: Martins Ferry,OH
| Battery conector bad
Ok well I've been playing around with my micro and every now Nd then it stops and I think it's the battery connection what should i do
10-01-2010, 03:38 PM | #2 |
Quarry Creeper Join Date: Jul 2010 Location: Independence
cant u just replace the connector?
10-01-2010, 05:17 PM | #3 |
RCC Addict Join Date: Oct 2009 Location: In the mancave...
did you check the soldered connection on the battery? my stock batteries did this a few times and, in my case, it was because the wire(s) broke off the battery. i just re-soldered them on. but to answer the question above. yes, i believe you can buy new losi connectors. i think they come with the wires already on them. which, means you'd have to solder them onto the battery.
10-02-2010, 01:07 AM | #4 |
Quarry Creeper Join Date: Aug 2010 Location: Brisbane Australia
Better yet if you have to replace the plugs convert them over to micro deans as they are much better.
10-02-2010, 04:19 AM | #5 |
I resoldered them and seems to work fine
10-02-2010, 05:34 AM | #6 |
