11-03-2010, 08:18 PM | #1 |
Newbie Join Date: Mar 2008 Location: DFW
| Jitter Issues
Figured someone has had this issue or might know where to really start looking. When you turn the wheel one way it sits and goes full turn back and forth about 5 times after you turn. Just started doing it a couple of weeks ago. I thought the battery was bad so upgraded to the LiPo version from Losi, still does it but runs really fast now. I don't get jitter on the throttle just the steering. BND Version Spectrum 3.0 All electronics stock. |
11-03-2010, 08:31 PM | #2 |
Rock Crawler Join Date: Mar 2008 Location: Grand Rapids
stock servo? ...thats what mine did. it means your servo is toast also kow as the twitch of death upgrades are cheap hitec 65 or 55 are good and cheap tower has a few too. i use a spektrum h3000 high torque heli servo its about the same as a hitec 65mg but a little faster and has an aluminum heatsink
11-03-2010, 09:09 PM | #3 |
I kind of thought that was the issue. Think I have one in another car I just bought and never used, will try it out then upgrade.
11-03-2010, 09:43 PM | #4 |
Rock Crawler Join Date: Feb 2009 Location: Milwaukee
11-04-2010, 05:55 PM | #5 | |
Newbie Join Date: Jul 2010 Location: Parker, Co.
11-04-2010, 05:56 PM | #6 |
Already changed the batteries, had a HiTec 55 but doesn't quite fit the same. going to have to do some modifying it looks like.
11-05-2010, 12:07 AM | #7 |
just loosen the servo mounts a little and you should be good to go |
11-07-2010, 09:25 PM | #8 |
Rock Stacker Join Date: Mar 2010 Location: meridian
i just put the hitec 56 hb in mine. the stocker in mine did the same thing. Fixed it immediately, Good luck.
12-11-2010, 01:23 PM | #9 |
Pebble Pounder Join Date: Feb 2010 Location: yankees suck
Haha mine started up too, are any servos a direct fit, or just get a hitec?
12-11-2010, 01:44 PM | #10 |
Pebble Pounder Join Date: Nov 2008 Location: Littleton
