12-14-2010, 01:42 PM | #1 |
RCC Addict Join Date: Jun 2007 Location: MESA
| Tail Rotor Motors?
I saw a post the other day on here where someone showed a tail rotor motor #CN12-RXC that he was trying to sell "illegally". That post is now gone...surprise!!! In that post he mentioned a guy that had used it in a build. I tried finding that post on the build and couldn't. Does anyone know how well these motors work and if they are a good option? He did state that it had more torque and never got hot...that got me interested. |
12-14-2010, 04:48 PM | #2 |
Pebble Pounder Join Date: Feb 2010 Location: Canada
I would just go for it...for 11 dollers on some sites its a steal.....and it also got me interested but I'm saving my money for my supplies for my build.
12-14-2010, 05:56 PM | #3 |
Quarry Creeper Join Date: Jul 2007 Location: Sierra Foothills
| Motor
I picked one up off of EBay will try it out soon. The motor is definitely not a direct drop in replacement. The mounting holes are closer together than the stock motor, plus it has a pretty big bushing where the armature comes out of the motor case.
12-14-2010, 06:18 PM | #4 |
Thanks for the heads up. I will keep my eyes open on info on them.
12-14-2010, 06:59 PM | #5 |
Rock Crawler Join Date: May 2008 Location: At the corner of Bedlam and Squalor.
Does anyone happen to know what model/size the stock motor is? You can be sure it's not a custom size. Find that out and the options will open up.
12-14-2010, 08:17 PM | #6 |
SPECS: Motor length: 1.29" (33mm) Motor diameter: .50" (12.7mm) Performance: 6V amps 1.35,Thrust 51g,Power 8.10 Watts, Efficiency 6.30(g/W) 7.2V amps 1.66,Thrust 60g,Power 11.95 Watts, Efficiency 5.02(g/W I'm not completely sure these are these are correct but this is where i got the info: http://www3.towerhobbies.com/cgi-bin...P?I=LXHHM6&P=8 |
12-15-2010, 08:30 AM | #7 | |
I saw that too. I sent an email to GWS and asked them the turns and what size shaft it is. Hope they reply. | |
12-15-2010, 07:34 PM | #8 |
I wanna be Dave Join Date: Feb 2007 Location: South FL
Seems like you are talking about helicopter outrunner motors these are the only ones Ive seen used in the losi micro http://www.hobbyking.com/hobbyking/s...idProduct=6312 They are so cheap i picked up 2 with a bigger order a while ago but haven't had my crawler back together to try them keep in mind for most if not all of the micro out runner motors you will need to cut and modify the motor mounts the one i linked you will need to remove a clip off the shaft so you can slide the shaft to the other end of the motor do an advanced search in the Losi micro area and the Micro scale forum for "outrunner" and "out runner" you will find a few posts of people who run the same motor. One goes into more detail on how to move the shaft |
12-16-2010, 12:17 PM | #9 |
they are not talking about brushless motors. they are a brushed motor for the tail rotor to a heli that looks like a longer version of the stock motor
12-17-2010, 08:38 PM | #10 |
RCC Addict Join Date: Aug 2005 Location: Naoma, WV
| http://www.rccrawler.com/forum/showt...77#post2733577 Does anyone know any other brands of longer tailrotor motor? I'm about to place an order from RPP and they don't carry this one. |
12-17-2010, 08:46 PM | #11 | |
Pebble Pounder Join Date: Sep 2009 Location: Michigan
this motor is slower and has more torque than stock. and mine gets HOT! hope this helps | |
12-18-2010, 11:04 AM | #12 | |
12-18-2010, 03:18 PM | #13 |
I would say just right on the torque. Although I never used it with the stock drive shafts. There is a heat sink you can get for it.
