Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Heritage Crawlers > Losi Micro-Rock Crawler
Thread: D-Shaft for micro wheels ?
Old 01-25-2011, 09:24 PM   #1
Default D-Shaft for micro wheels ?
I know i saw a thread a while back that a small hex was available for the micro wheel, that splined onto a d-shaft. Pretty sure it was on ebay.uk or something to.
I just went back the first 21 pages and didnt find it but will keep searching as well.
Any help is greatly appreciated.
Thanks guys.
ScalerLover is offline   Reply With Quote
Old 01-26-2011, 06:08 AM   #2
Thanks guys.
dunno about the hex but I seen someone put Rock Crushers on 1/24 Rally rim and but them on the SCT and looked cool on the micro t forums
Edit: looks like backwards mounted rallys
http://img259.imageshack.us/img259/4700/p1000834c.jpg
Mav68erick is offline   Reply With Quote
Old 01-26-2011, 09:24 AM   #3
these ones ?
http://www.customcuts.de/epages/6213...C%20Adapter%22
chevy55 is offline   Reply With Quote
Old 01-26-2011, 09:43 AM   #4
Originally Posted by chevy55 View Post
"With this adapter one can install MiniZ rims on its 1:24 MiRC"
kinda neat
SlayerXJ is offline   Reply With Quote
Old 01-26-2011, 05:56 PM   #5
Wrong ones, i want to put micro wheels on a d-shaft.
Maybe those are the ones i saw and its been a while my brain just thought i saw what i needed
Phewy, guess its to the drawing board for a custom hex....
Old 01-26-2011, 10:19 PM   #6
If you take a set of stock losi crawler wheels and cut them like you where goning to spin the hex around to widen them. the Stock micro sct wheels will slide snug inside the center of the crawler wheels.
Ratboy99 is offline   Reply With Quote
Old 01-27-2011, 07:06 AM   #7
Cool, ill order some up to try when i get some cash.
The main thing on these us keeping them skinny though, the axles are already pretty wide.
Old 01-27-2011, 05:02 PM   #8
the d shaped ones are for converting model car wheels to fit xmod wheel shafts and as far as i know there not made anymore and they wont be for awhile as the guy who made them only made a certain amount for his own shop to sell on his website
Xmods Aluminum Model Car/Truck Rim Adapters
http://www.xmodsinternational.com/se...=search&page=1
and i wouldnt trust the custom cuts ones as i got some last year for a xmod and they were to wide for the wheel shaft
boohoo is offline   Reply With Quote
Old 01-28-2011, 09:11 PM   #9
Scale Detail Engineering
ha, I'm in the process of puting stock crawler tires on a micro rally.
If it works, I'll spring for the roks.
I was really disapointed that at 1/24 they put D shafts on the sct!
I was looking forward to some cac wheels.
johnnyh66 is offline   Reply With Quote
Old 01-29-2011, 02:13 AM   #10
If you slip the crawlers rims over the sct rims they keep the same backspacing as the stock sct so it only gets a tiny bit wider.
Old 01-29-2011, 07:16 AM   #11
Might try it some time.
For now i came up with something. I cut the d-shaft wheel apart, kept the center and made a hex out of it haha. Works perfect and keeps the stock micro wheel backspace.
Old 01-29-2011, 09:52 AM   #12
Just a thought, but can you cross drill the d shaft and put a pin through like the micro crawler? Then maybe it would bolt up without having to mod the wheel, if you wanted to go back to the stock D shaped wheels, just pull the cross pin out and slide the old wheel back on?
**EDIT** Just checked, wont work. The shafts are different diameters, too much slop!
getbent is offline   Reply With Quote
Old 02-19-2011, 12:24 AM   #13
Does this mean you can use SCT tyres/wheels on a Micro (crawler) Scale car ??
How wide will it be ??
(Asking because I need smaller wheels on my scaler and want to keep the width approx. like the micro crawler).
KuJo is offline   Reply With Quote
