Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Heritage Crawlers > Losi Micro-Rock Crawler
Thread: Which lipo to buy?
Old 02-11-2011, 06:40 PM   #1
Default Which lipo to buy?
Hey all just got a new micro and I see that a lipo is the way to go for more power and run time. I tried searching for this type of question but came up empty. I'm not looking to do many mods other than this and a body and the freebie mods people have done. I just figure longer run time sounds fun. There's lots of packs and chargers and combos for sale on eBay. So I ask you which is the best to get and why? I want to keep the cost low but if one is $20 more than another but is a million times worth getting I'm in. Thanks for the help
sky56 is offline   Reply With Quote
Old 02-11-2011, 06:55 PM   #2
For this question My standard answer...
http://cgi.ebay.com/Losi-Micro-Rally...item230e0721c4
Or similar.
T-buck is offline   Reply With Quote
Old 02-11-2011, 07:17 PM   #3
Great thanks. Found one on eBay same one from same company. Do I need to buy a charger for it and what plugs do I need to change according to the description?
Old 02-11-2011, 07:26 PM   #4
You need a charger that can do lipo's, one w/adjustable charge current.
this thread has some info on chargers.
lipo chrger
Losi's batt & charger
http://www.losi.com/Products/Feature...rodId=LOSB0862
Old 02-11-2011, 08:15 PM   #5
Midlife Crisis's Avatar
I went with 2 Losi 2c 7.4v LiPos and the standard Losi wall charger. Sure, it was expensive, but plug and play for my micro desert truck and crawler. I love it, 45 minutes of run time between the two packs. Horizon Hobbies is where I got 1 batt and the charger.
Midlife Crisis is offline   Reply With Quote
Old 02-12-2011, 07:08 AM   #6
I have the losi 7.4 180 mah has a lot more power but the run time is only 10 to 15 mins. I thought it would have been longer than the stock battery but it's not. I use my lipo battery charger I didn't get the wall plug one and it still takes 50 minutes to charge at .2 amps. I may go to .4 amps (2c) and try that. I will be looking into a bigger mah battery soon.
Gso125 is offline   Reply With Quote
Old 02-15-2011, 11:44 AM   #7
sky i picked up some thunder power 7.4 250mAh ... and wow is all i have to say have to relearn how to use all the power ...
regal200021 is offline   Reply With Quote
Old 02-15-2011, 01:48 PM   #8
Hey regal do you have more info on it? Do I need to get a charger? If so which one thanks
Old 02-15-2011, 02:19 PM   #9
i had an ice charger ...so ya you will need a charger ... thunder power lipo 7.4 250 mAh i just googled it ..
