02-11-2011, 06:40 PM | #1 |
Newbie Join Date: Feb 2011 Location: chicago
| Which lipo to buy?
Hey all just got a new micro and I see that a lipo is the way to go for more power and run time. I tried searching for this type of question but came up empty. I'm not looking to do many mods other than this and a body and the freebie mods people have done. I just figure longer run time sounds fun. There's lots of packs and chargers and combos for sale on eBay. So I ask you which is the best to get and why? I want to keep the cost low but if one is $20 more than another but is a million times worth getting I'm in. Thanks for the help
02-11-2011, 06:55 PM | #2 |
Rock Crawler Join Date: Feb 2009 Location: Milwaukee
For this question My standard answer... http://cgi.ebay.com/Losi-Micro-Rally...item230e0721c4 Or similar. |
02-11-2011, 07:17 PM | #3 |
Great thanks. Found one on eBay same one from same company. Do I need to buy a charger for it and what plugs do I need to change according to the description?
02-11-2011, 07:26 PM | #4 |
You need a charger that can do lipo's, one w/adjustable charge current. this thread has some info on chargers. lipo chrger Losi's batt & charger http://www.losi.com/Products/Feature...rodId=LOSB0862 |
02-11-2011, 08:15 PM | #5 |
Rock Crawler Join Date: Dec 2010 Location: Madison Co.,Ms.
I went with 2 Losi 2c 7.4v LiPos and the standard Losi wall charger. Sure, it was expensive, but plug and play for my micro desert truck and crawler. I love it, 45 minutes of run time between the two packs. Horizon Hobbies is where I got 1 batt and the charger.
02-12-2011, 07:08 AM | #6 |
Quarry Creeper Join Date: Dec 2010 Location: Princeton Mass
I have the losi 7.4 180 mah has a lot more power but the run time is only 10 to 15 mins. I thought it would have been longer than the stock battery but it's not. I use my lipo battery charger I didn't get the wall plug one and it still takes 50 minutes to charge at .2 amps. I may go to .4 amps (2c) and try that. I will be looking into a bigger mah battery soon.
02-15-2011, 11:44 AM | #7 |
Rock Stacker Join Date: Jan 2007 Location: Caledonia MN
sky i picked up some thunder power 7.4 250mAh ... and wow is all i have to say have to relearn how to use all the power ...
02-15-2011, 01:48 PM | #8 |
Hey regal do you have more info on it? Do I need to get a charger? If so which one thanks
02-15-2011, 02:19 PM | #9 |
