03-25-2011, 10:46 AM | #1 |
Quarry Creeper Join Date: May 2010 Location: scotland
| esc wiring help
can anyone please post of a pic of the esc decased as two of the wires on mine have came off and iam not sure were they go thaks
03-25-2011, 10:56 AM | #2 |
Rock Crawler Join Date: Feb 2009 Location: Milwaukee
Here you go... The wires under the servo plug are for the motor, The other side is for Battery. |
03-25-2011, 11:02 AM | #3 |
03-25-2011, 12:46 PM | #4 |
Pebble Pounder Join Date: Mar 2006 Location: Lake Charles, LA
Anyone else's esc have a bad connection. Mine seems to have bad wires or something because I have to move it around outside of its case to get it to work sometimes. Has anyone had luck re-soldering theirs?
03-25-2011, 07:18 PM | #5 |
Sounds like a loose wire?? Thats what I would check for first. I haven't had any w/bad connections but I've re-soldered couple of them w/no issues so far. |
03-25-2011, 07:46 PM | #6 |
Newbie Join Date: Dec 2010 Location: Canada
Hi, is it worth it to keep the on/off switch ? I was thinking of removing it, that way when you Plug the battery it's on, when you unplug it it's off. But no one is doing it, is there a reason to not doing it? |
03-25-2011, 08:16 PM | #7 |
Rock Crawler Join Date: Mar 2008 Location: Grand Rapids
i re wired mine with 22ga noodle wire and i ditched the switch as soon as i got it ...i never use switches on any of my rigs never really saw a point to it
03-26-2011, 10:45 PM | #8 |
I was considering ordering this wire to use to resolder my esc, has anyone used it before? Is 20ga going to be to big? http://www.amainhobbies.com/product_...ed-Black-180cm |
