03-27-2011, 09:32 AM | #1 |
Pebble Pounder Join Date: Mar 2006 Location: Lake Charles, LA
| Stock links with aftermarket chassis?
I am looking at the aftermarket chassis' out there. I have the trail trekker and was wondering if I could get away using the stock links on a chassis like the TMC Blade or the Eclipse? I am sure that I would build my own links in the future but I would like to just use the current links if possible. Any input?
03-27-2011, 09:44 AM | #2 |
Rock Crawler Join Date: Feb 2009 Location: Milwaukee
You could use the stock links, The thing w/making your own is you get the w.b. you want & the extra length seems to really help. Stock links will work, Just not my thing. |
03-27-2011, 10:26 AM | #3 |
Thanks T-buck, that was my assumption but wanted clarification from someone with more experience. Thanks again for the info!!
03-27-2011, 10:36 AM | #4 |
Rock Crawler Join Date: Dec 2005 Location: houston
The eclipse requires one set of custom links, if you re-use the lower links you will have to make new upper links and vice versa, due to the design of the chassis. Just FYI. But I wouldnt let that be my decision maker, links are super easy to make, just choose the chassis you like the best and make it work. Good luck! |
03-27-2011, 10:38 AM | #5 |
Thanks getbent. Good info to know ahead of time. BTW while I have you, any word on those awesome motors of yours I have read about?
03-27-2011, 10:42 AM | #6 |
| I should know everything and have made a decision within the next week and a half to two weeks. I will post the decision either way, thanks for your interest! |
03-27-2011, 11:16 AM | #7 |
Quarry Creeper Join Date: Sep 2005 Location: LRAFB
i run the stock link on my tmc works great every thing is stock on it but the tmc this almost a vertical climb Last edited by alterchristopher; 03-27-2011 at 11:19 AM. |
03-27-2011, 09:47 PM | #8 |
Thanks a bunch for the video clip and pic alterchristopher. That thing looks really capable and makes me really lean in the direction of the TMC.
03-28-2011, 12:21 AM | #9 |
Rock Stacker Join Date: Aug 2006 Location: everett
I have the tmc chassis and use stock trekker links. I think they are perfect length for it. The trekkers links are already longer than the micro crawlers by quite a bit. Its actually longer than my extended lmc. But links are easy and cheap to make. Custom ones look better imo and of course bending the lowers helps. Sent from my epidemic 4g using Tapatalk |
03-28-2011, 09:34 AM | #10 |
Quarry Creeper Join Date: Apr 2010 Location: Southern Aroostook County
just my $.02 worth but I just bent the ears of the TVPs 90 deg. toward the inside of the chassis to inboard the shocks and it works great! This one is bone stock with no mods except that Im running a 250mah 1s lipo and a decased ESC, I did bend the upper links in a little to clear the tires at full steer. Big improvement over stock ,smooth atric. slightly lower COG and FREE. I have 3 micros, 1 w/ a DP torsion chassis, 1 w/ modded shocks and home built links and the one I just described. The last one is my got to rig because it performs really well, better than the other 2 IMO... |
03-28-2011, 09:49 AM | #11 |
Pebble Pounder Join Date: Jan 2011 Location: USA
The TMC chassis works really well and has many ways to set it up customized to your crawling style. Check my rig with a modified TMC chassis that works with a body comp style: LMRC Phantom Carbon 01 Here's a link to the chassis: http://www.crawlerx.net/index.php?ma...roducts_id=111 *CrawlerX service is top notch! |
03-29-2011, 09:56 AM | #12 |
I ran my Pinch chassis with stock links all last year it worked amazingly well. I made links and modded the drive shafts to 4 3/8" for this year and it's much better.
