03-27-2011, 08:57 PM | #1 |
Newbie Join Date: Mar 2010 Location: La Crosse
| If Papa Smurf Drove a Rock Crawler...
Thought I would share some photos of my Micro Crawler... The chassis if made out of plate aluminum, four wheel steering, hi-tech hs55 servos, aluminum links, slightly lengthened wheelbase, semi-drooped suspension with the springs shortened and hooked to either end of the shock, two 3.7 volt single cell 250 mah lipos run at 7.4 volts, xcelorin 8750kv brushless micro motor, spektrum sr 300 receiver decased and heat shrunk, aluminum skid plate... I am sure I am forgetting something, if I think of anything later I will add it to the list. |
03-28-2011, 02:18 AM | #2 |
Pebble Pounder Join Date: Jan 2011 Location: USA
Very nice! |
03-28-2011, 09:28 AM | #3 |
How's that xcelorin 8750kv working for you? I picked one up but put it in my micro sct. |
03-28-2011, 12:10 PM | #4 |
The brushless works great, it takes a bit get used to feathering the throttle, but it has a ton of power available . If you need to get up and over something it'll do it that's for sure. It helps having two 250 mah lipos powering it. The only thing I have a gripe with is the extra chassis weight, the extra traction is perfect, but it is a little top heavy. I need to do a little work with the springs and shock setup, I have a few ideas in mind that should help a quite a bit.
03-28-2011, 02:34 PM | #5 |
Pebble Pounder Join Date: Mar 2006 Location: Lake Charles, LA
How is the low end torque? You mentioned feathering the thottle, does it still slow speed crawl? Any issue with cogging?
03-28-2011, 04:11 PM | #6 |
There can be, but the usable power is enough that the only time it's noticeable is when you have a tire pinched or pinned against or in an obstacle. With that in mind the motor doesn't take any time to build power, if you can get any kind of "stab" with the throttle the motor winds up to usable power nearly instantly. Of course the upside is that when you can turn that many rpms geared as low as you can get it, the whole powerband is very smooth. So it kinda seems like a "six of one thing, half a dozen of the other" sort of situation, more a personal feel issue than anything.
03-28-2011, 05:22 PM | #7 |
any video of it? would love to see the brushless in action. What gearing are you running?
03-28-2011, 07:36 PM | #8 |
I'll try to get some video uploaded, haven't been able to find the adapter for my video camera tripod will see what I can figure out though. Using the lowest gearing that comes with the kit. In order to get the motor to mount up to the stock tranny plate/case you have to get a little creative with the dremel tool, nothing too bad just a little trimming.
03-29-2011, 09:07 AM | #9 |
Yup, that's why I didn't put it in mine, it didn't fit! I think it would fit the stock motor mount if you used a larger pinion but then you'd have other problems.
