04-24-2011, 09:48 PM | #1 |
Newbie Join Date: Mar 2011 Location: mile high city
| AUX servo setup ?
So I was trying to get the dig servo setup for my comp. I set the high and low throw to the correct distance. But every time I turn on the Crawler it sends the servo back a forth to "center" it or something . And it goes way farther then I set it. Is there a way to make it not center every time I turn it on. ? Its so much that I can't even mount up every time it does that , It will f shi) Up... if that makes any sense ... if I can't make it stop there is no way to make this dig work .not enough room to have it swinging all over in the cab ...
04-24-2011, 10:32 PM | #2 |
Spectrum dx3$ ...sorry
04-25-2011, 08:55 AM | #3 |
No one has ever setup a auxiliary servo?
04-25-2011, 09:53 AM | #4 |
Quarry Creeper Join Date: Jan 2011 Location: Detroit and Denver
| use the search button ya newb!!!! lol!!!!
04-25-2011, 12:46 PM | #5 |
Rock Crawler Join Date: Dec 2005 Location: houston
Is there a trim knob for the 3rd channel on the DX3s? Not the end point adustments, as that should only effect the channel in the switched position. The neutral position as far as I know can only be adjusted with a trim knob (if it has one) or by linkage adjustment. I set my dig servo by putting the 3rd channel switch in the neutral position, turning everything on and letting the servo find its center, then installied the servo arm in the position closest to where I needed it, then adjusted the servo linkage and actual placement of the servo to get everything sitting in the right spot in the neutral position. Then I switched the 3rd channel and used my EPA adjustments to get that set just right. I dont own a dx3s and Im definitely not on expert on setting up transmitters, but thats what worked for me. Good luck! Hope that made sense. |
04-29-2011, 07:06 PM | #6 |
Newbie Join Date: Jan 2009 Location: Brampton, Ontario
On a DX3R, you have to set the 3rd channel to either 2 or 3 position, depending on what you want. I'm guessing you only want 2 position. As stated before, connect your servo and let it center on it's own. Make sure your AUX trim is zeroed as well. Attach your servo arm to the servo, but do not connect it to the dig. Play around with the 2nd position and adjust the Travel as needed. Connect your servo arm to dig and fine tune with AUX trim. Hope this helps/what you're looking for.
