08-14-2011, 06:52 PM | #1 |
Quarry Creeper Join Date: May 2011 Location: USA
| Servos... what do you use, and why...
Searching the forums for "servo" results in just about every post in the forum coming back as a hit. I am servo researching. I want to replace the 65MG Hi-Tech servo I have and I'm not having much luck finding a whole lot of reviews and diversity out there. So, what have you read, or used, or like... and why? Also include any issues with mounting if you went with a smaller or larger sized servo! |
08-14-2011, 06:58 PM | #2 |
Quarry Creeper Join Date: Apr 2011 Location: North Alabama
I use the Tpro mg90s. They are metal geared and ahve the same power output as the hitec. They are a fraction of the cost as well. I got 4 of them from hobby partz for like 25 bucks shipped.
08-14-2011, 07:16 PM | #3 | |
Quarry Creeper Join Date: Apr 2011 Location: Dallas
08-14-2011, 07:24 PM | #4 |
Pebble Pounder Join Date: Nov 2004 Location: Charles Town
Probably doesn't help, but I use the hs-65hb (karbonite gears vs the metal gears, local hobby shop had it in stock and I had some store credit to use, so it worked out)
08-14-2011, 08:39 PM | #5 |
Rock Crawler Join Date: Dec 2010 Location: Madison Co.,Ms.
Seems crazy you'd want to replace pretty much the best you can get. Have you looked into Spektrum's offerings?
08-14-2011, 10:40 PM | #6 |
My hi-tech is faulty. Not sure exactly what is going on but turning to the right it gets to a point and a feather will stop it from turning further right. And this problem is intermittent, about 8 of 10 turns to the right have this issue. Turns to the left like a champ.
08-14-2011, 11:21 PM | #7 |
Rock Stacker Join Date: Aug 2006 Location: everett
I'm using the tpro mg as well. It works great and its super cheap. Sent from my SPH-D700 using Tapatalk |
08-15-2011, 12:29 AM | #8 |
A 7950th... Do the rear tires even touch the ground with that thing on!?
08-15-2011, 02:27 AM | #9 |
Newbie Join Date: Jul 2011 Location: Ellisville MS
Using a Spektrum A3040 and it's plenty strong and very smooth. Picked it up for around 18 bones I believe. Heard some metal arms are about to be released for them.
08-15-2011, 10:55 AM | #10 |
I'm really curious about this servo; http://www.savoxusa.com/Savox_SH0256.../savsh0256.htm It has the most torque of any servo I've ever seen that size. And I'm also curious about this servo; http://www.horizonhobby.com/Products...8HV#quickSpecs That servo is a tad to big, but I wonder if it would work if I used spacers on the mounting bracket. |
08-15-2011, 11:11 AM | #11 |
And it bugs me a little about these servos only being spec'd to 6v...
08-15-2011, 06:03 PM | #12 | ||
I wanna be Dave Join Date: Feb 2007 Location: South FL
Honestly I think you just got a lemon, hitech is a popular quality brand. you can either try another or pick up 3 or 4 of the $9 metal gear servos everyone uses. I have a few from ebay that are identical visually and spec wise to the TG pro or whatever. for the $ if they die they servo boards make great LED,winch controllers,or micro ESC's | ||
08-15-2011, 06:04 PM | #13 | |
and as far as the other i would never spend $75 for a micro servo on a $70 micro crawler haha | |
08-15-2011, 10:36 PM | #14 |
| All 2s LiPo's are 7.4 volt, that means everyone running a 2s LiPo upgrade are over-volting their servos.
08-15-2011, 11:21 PM | #15 | |
i dont know about the stock losi micro ESC but to my understanding thats how the aftermarket ESCs are that and and get more power and torque with the stock motor | |
08-15-2011, 11:22 PM | #16 |
Newbie Join Date: Mar 2010 Location: Rancho Cucamonga
I have been very happy with the Hitec and have it on all three micros I have. Try running with 1s2p LIPO instead of the 2s. It really makes a big differnce ant it runs like a crawler and not a rock racer.
08-16-2011, 12:05 AM | #17 | |
I'll use the ESC from my Trail Trekker and put it in my Micro Crawler, that'll give me more speed and torque for certain! Well, I have a 90t motor in mine, so it's slow. But I'm not sure the stock ESC/RX is meant to go lower than 4.8v, and undervolting things can have bad effects too... but I'm not sure on that one. | |
08-16-2011, 01:15 AM | #18 |
From what i understand the simple version is this. a typical setup has power from battery to power the ESC. it goes to the motor at whatever the batt voltage is, and powers the RX and anything plugged in at whatever the internal BEC is set at.(lets just say 5v) to get more power to the servo(6v+) and to run higher voltage batteries without freaking out or frying the internal BEC you use an external BEC which is also attached to the battery. it bypasses the ESC and internal BEC and plugs into the RX on the VCC/batt/ side. this now powers your RX and anything plugged into it at the voltage set by the external BEC (6v+)which is why you see people remove the middle red power wire from the ESC plug going to the RX, otherwise the ESC and external BEC would both power the RX thats the way suggested by castle for the castle BEC But Ive also seen some who want to power the RX as normal (5v) but for the servo they wire it directly to the BEC for power (6v) and signal of course goes to the RX, Im not sure what advantage this has if any, other than keeping a lower voltage to everything else plugged into the RX and the RX itself. that being said I dont think we will need an external BEC for these micros. a decent servo and 2Cell lipo should be plenty |
08-16-2011, 08:16 AM | #19 |
Quarry Creeper Join Date: Feb 2008 Location: The Schwa
I just tried the "MKS P03 No.4 Copper Gear Servo 10g/2.9kg/.1sec", from Hobby King. Strong, precise, quick, small and cheap.
08-16-2011, 03:43 PM | #20 |
RCC Addict Join Date: Jan 2009 Location: Jacksonville Illinois
That HK servo direct bolt on? I've had good exp from HK products the last few years --- Last edited by CrawlinMike; 08-16-2011 at 03:46 PM. |
