09-25-2011, 05:26 PM | #1 |
Newbie Join Date: Dec 2010 Location: Michigan
| motor upgrade
What motor are you guys upgrading to?
09-25-2011, 05:55 PM | #2 |
I wanna be Dave Join Date: Feb 2007 Location: South FL
| Search around for Getbents hand wound predator motors and get on the waiting list. its the easiest way and only direct no mod swap. you will find nothing but great reviews and people who want to be on the waiting list. its direct swap,no need for a new ESC, affordable, dual ball bearing and tons of torque. ( i dont have one but every review says this ) another option is for a bigger 130 can motor like used with Xmods and miniZ. search for the Big Block mod for Chevy55. however the shaft is bigger so you will need to modify a pinion and you will need to make a motor plate or modify the existing plate |
09-25-2011, 07:56 PM | #3 |
Quarry Creeper Join Date: Apr 2011 Location: Dallas
the Predator motor is badass. I have a 90t with Miclaw tires. Works great. Upgrade to a 2s lipo before the motor tho. It might be the upgrade you are looking for. If not...then upgrade motor. Get on the waiting list anyways. You will be there a while.
09-25-2011, 08:06 PM | #4 |
Newbie Join Date: Sep 2011 Location: Stephenville
I went with one of the micro size outrunners on hobbyking, I had to go all new electronics but this little motor will not stop for anything. I could probably spin the mqlow tires right off my rims. mounting was easy and installing all the stuff is breeze.
09-25-2011, 08:09 PM | #5 |
| What Kv did you go with? How fast is it? Im looking for crapload of torque and a bit more wheel speed. What ESC did you choose? What battery voltage you run?
09-25-2011, 08:26 PM | #6 |
Im building a 1/20 scalier.
09-25-2011, 08:28 PM | #7 |
| If he is using the 5gram 2000kv that everyone else uses it may not have the speed you are looking for though it has torque, there is a larger 3000kv outrunner I picked up and havent tried yet but I have a feeling the 80T 130 motor would be better with your setup. gobs of torque and speed
09-25-2011, 08:35 PM | #8 |
| A scaler will use the same motors, if its just a scaler maybe run the stock motor and lipo and see how you like it with the weight first? still wouldnt hurt to get on Getbents list. if you decide you dont want it once you get it Im sure it would sell within hours of you posting it FS.
09-25-2011, 10:12 PM | #9 |
RCC Addict Join Date: Nov 2007 Location: -
dude. Getbent's motor are like 20years(exageration) till you get one. I probably wont get one. But hopefully I do.
09-25-2011, 10:59 PM | #10 |
Quarry Creeper Join Date: Oct 2010 Location: NOR-CAL
I want a 90t from GETBENT.Hopefully he'll have some soon.
09-27-2011, 12:10 PM | #11 |
Wait for a Getbent motor you won't regret it they are awesome, the only game it town for Micro performance.
09-27-2011, 12:19 PM | #12 |
09-27-2011, 02:38 PM | #13 |
Rock Stacker Join Date: Jul 2006 Location: moab
Not to rip on anybody but I've had 2 predator 80t motors from get bent with the lowest gearing possible and stock size tires and power out allot. I think I will be going with the outrunner motor next.
09-27-2011, 08:34 PM | #14 |
Rock Stacker Join Date: Jan 2009 Location: Calgary
If someone were ya know...lazy... would someone have a link to the outrunner motor people are talking about?
09-27-2011, 08:41 PM | #15 |
A 130 can motor might be a better choice, that way you dont need a new ESC and RX
09-27-2011, 08:42 PM | #16 |
Rock Stacker Join Date: Aug 2006 Location: everett
| http://www.hobbyking.com/hobbycity/s...idproduct=6312 For the 2000 Kv outrunner I'm running it and like it a lot. People complain about wheel speed but it has lots of torque. I just geared mine higher and its comparable to stock speed with lots of torque and low speed control. Sent from my SPH-D700 using Tapatalk |
09-28-2011, 01:05 AM | #17 |
Newbie Join Date: Jul 2010 Location: Netherlands
edit: put some wrong info here, my bad ;)
09-28-2011, 01:24 AM | #18 | |
Rock Stacker Join Date: Sep 2011 Location: Saint Clair Shores
09-28-2011, 03:18 AM | #19 |
Quarry Creeper Join Date: Apr 2011 Location: North Alabama
you have to do a little custom fab. nothing hard though. mine should be here in the next day or so. When I go to mount mine I am going to take a few pictures to show how I did it. I am curious about the larger outrunner that spoo76 mentioned. I have ran the stock and the 80t Predator motor. I wont knock the predator as even on nimh batteries you can tell a difference.
09-28-2011, 05:20 AM | #20 | |
| search the micro area for outrunner you will see a few installed pix from others and a ive posted a link a few times to a thread elsewhere about installing these Quote: | |
