11-24-2011, 03:17 PM | #1 |
Newbie Join Date: Mar 2011 Location: Caledonia
| Soldering brass questions?
Hey when building tubers out of brass how do you solder it? My last attempt with it I used a tourch like sweating copper lines. But as soon as I would try the next joint the first would fall off.
11-24-2011, 05:51 PM | #2 |
Rock Crawler Join Date: Oct 2011 Location: minot
Check out my tuber build thread. Its brass and soldered. I used cheap radioshack lead free solder and a 40watt ungar iron. Flux both surfaces, tin the iron and heat the surfaces. Once both surfaces are tinned they will bond when they cool. I used a wire soldering "third hand" rig with two alligator clips on a stand to hold the chassis pieces in place while I heated them. Feeding solder into the joint while they are hot will build it up making it stronger. Flux, solder, and the third hand assy came from radioshack. |
11-24-2011, 08:06 PM | #3 |
Rock Crawler Join Date: Oct 2011 Location: Lexington
I use the "helping hands" tool all the time when I solder. Makes working on wiring and tubing a whole lot easier, plus they usually have a magnifying glass i you're working on really small stuff.
11-25-2011, 07:50 AM | #4 |
Quarry Creeper Join Date: Apr 2011 Location: Dallas
you will have to get something to act as a heatsink. I bought 2 spring closed tweezers that work well from LHS. With these I can bond the tubing about 2mm from a previous joint. I use a small torch BTW.
02-06-2012, 10:08 AM | #5 |
Quarry Creeper Join Date: Nov 2010 Location: Montreal
| Re: Soldering brass questions?
so I guess you can solder a regular 3/16 rod with tin solder and electric iron? That would be great for inside..no torch and no smoke or crappy odor...you guys got a specific soldering tip for that? I have a hakko 936...I guess it could do the job when temp is ajusted to the max?
02-06-2012, 04:55 PM | #6 |
i was using the 1/4inch wide tip to heat the joints. the third hand "helping hand" thing is a must. i moved from the iron to a small butane torch. rough up the contacting surfaces a little, tin them, place them together, heat them and feed solder into the joint.. instant tuber. |
