Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Heritage Crawlers > Losi Micro-Rock Crawler
Thread: complete wheels and tires list!
Old 12-23-2011, 04:59 PM   #1
Default complete wheels and tires list!
ive been looking for ages for a complete list of tires and wheels and couldnt find one...so i im doing one here... and now!
in this thread you will see all aftermarket tires and wheels that fit the losi micro rock crawler (McRC) that i can think of lol.
you will see a pic of said item, dimensions, rating, where to get it, you get the jist of it.
also if there is info missing in this thread eg. dimension, url, even another item, let me know with said information and ill put it in this thread.if you are rating said item *-*****, * being very bad and ***** being exceptionally brilliant.
i really hope this makes a sticky so people get to the info they need with ease.
so without further adue lets start with wheels/rims whatever you wanna call them
WHEELS:
gearhead
Gear Head RC 8Trax Micro Crawler Wheels
Name:  gearhead black.jpg
Name:  gearhead silver.jpg
weight:???
hex: yes
rating:???
comments: comes in aluminiun, white delrin or black delrin.
url:Micro Crawler Wheels & Tires
HR
hr beadlocks
weight:???
hex: yes
rating:****
comments:good wheel, needs a #1 phillips for screws, rings come in red, blue, black.
url:Losi MICRO-ROCK-CRAWLER parts at the thetoyz.com - All your Losi MICRO-ROCK-CRAWLER parts in one superstore!
RC4WD
rc4wd micro beadlocks
weight: ???
hex: yes
rating: ****
comments: good all round wheel.
url:Losi Micro crawler Beadlock Wheel
BWD
micro vertex beadlocks
Name:  micro vertex.jpg
weight:???
hex: no, pin drive
rating:*****
comments: only BWD wideners work with these wheels. can use spent bullet casings (.17 hmr) to add weight and a little bling.
url:Micro Vertex's Silver
TIRES:
RC4WD
crusher x/t
Name:  rock crushers xt.jpg
O/D:48.3mm/1.90inch
width:18mm/0.70inch
rating:***
comments: good scale tire, not the best grip but not bad.
url:Rock Crusher Micro Crawler Tires
Rok Lox Micro Comp Tires
O/D:1.90"(48.3mm)
width:0.70"(18mm)
rating:****
comments: very good comp tire, plenty of grip, does very well on all surfaces.
url:Rok Lox Micro Comp Tires
Mickey Thompson Baja Claw TTC Micro Crawler Tires
Name:  baja claws.jpg
O/D:2" (51mm)
width:0.78" (20mm)
rating:***
coments: looks like there moving when they`re not!
url:Mickey Thompson Baja Claw TTC Micro Crawler Tires (pair)
Interco Super Swamper TSL/Bogger Micro Crawler Tires
Name:  micro boggers.jpg
O/D:1.98" (50.5mm)
width:0.78" (20mm)
rating:****
comments: micro version of the original, designed for that sticky situation!
url:Interco Super Swamper TSL/Bogger Micro Crawler Tires
RCTRAX
miniqlo miclows
O/D:approx 2.3"(60mm)
width: approx 0.94" (24mm)
rating:****
comments: big angry tires that will take anything.
url:RCTRAX Miclow Tire (2 pcs) : [MQ-MC01] : MiniQLO
[U]wideners[U]
stock width 3.38"(86mm)
crawlerx.net
extention:+0.39"(10mm)
material:delrin
rating:**
comments:overall 10mm extention over stock width, some cutomers experienced stripping or excesive wear and tear. ok product.
url:MICRO Wheel Widener Kit [MWW001] - $9.97 : Crawler X, Rock Crawler Parts
BWD
extention:???
material:aluminium
rating:???
comments: barrel nuts not inclded. only works with bwd wheels.
url:Micro Widener Hubs Only
LOSI
extention:+0.23(6mm)
material:alu/plastic
rating:****
comments: good cheap mod, overall 6mm extention over stock, easy mod.
url:Losi LOSB1737 - Micro 4x4 Stub Axles & Wheel Hexes
thats all i have for the time being guys, thanks for looking and remember if you have info you think needs to be in here let me know and ill put it in if its missing
also i recommend if you want a motor upgrade get a getbent 80t predator motor and a 90t if your going to use or already use miclows.
thanks again guys.
happy crawling.
lordjasper1988 is offline   Reply With Quote
Old 12-23-2011, 06:03 PM   #2
Midlife Crisis's Avatar
Default Re: complete wheels and tires list!
Nice work Man!
You should add widener links too.
On the wheel links, you should add what wideners will work or not work with them. Like, BWD wheels do not work with CrawlerX's widener kit. You should also add Danally's widened wheels link, since that is an option some will prefer over pricey wheels. Miniqlo and Sumo wheels/ tires are an option too. There's another company that sells Delrin and alloy wheels too, but I am spacing the name at the moment, LR Racing maybe???
Midlife Crisis is offline   Reply With Quote
Old 12-23-2011, 06:17 PM   #3
thanks bud right guys theres an idea let me know if you use wheel wideners and which rims you run on them ill ad it to the appropriate wheels also let me know which wheels and tires ive missed thanks again on the heads up bud
Old 12-23-2011, 07:14 PM   #4
the micro vertex are not on BWDs site now. Are they not going to sell them any more?
benny27 is offline   Reply With Quote
Old 12-23-2011, 08:52 PM   #5
Don't forget the LD Racing wheels. Non-beadlock and either black delrin or aluminum. Both are hex drive, but they don't list the weight. You can find them here: Micro Crawler Wheels & Tires I also didn't see Hot Racing's wheels. Those are beadlock and are very cheap, but don't fit the MiClaws unless you modify them a bit. You can usually find HR's wheels on ebay (either Bizarre Hobbies or Toadz RC, both of which are good sellers).
8695Beaters is offline   Reply With Quote
Old 12-23-2011, 11:13 PM   #6
[QUOTE=8695Beaters;
I also didn't see Hot Racing's wheels. Those are beadlock and are very cheap, but don't fit the MiClaws unless you modify them a bit. [/QUOTE]
Modding those wheels isn't necessary to run Miclaws, but is helpful. I've had mine mounted and unmounted at least 4-5 times without trouble and they are un-modded. FWIW, Bwd wheels have almost the exact groove and nobody has had to mod them. Pushing the bead lip into the groove before mounting the ring is the key for successful mounting.
Old 12-24-2011, 03:55 AM   #7
Talking Re: complete wheels and tires list!
hey guys thanks for the input and info, I'm not at the pc at the moment but ilk add the info asap, i will add the wheels mentioned above and also the wideners, just let me know what you want in and ill do it thanks again guys, let's hope this makes w sticky
Old 12-24-2011, 02:24 PM   #8
I'm down, but first let's get as much info in it as possible and all the vendors links, etc. There's a tire comparison pic somewhere in here that has them all lined up and shows the different sizes, etc.
Spoo?????
Old 12-24-2011, 02:28 PM   #9
I'm hoping to get as much info in it as possible. ill do my best with links etc but youll have to bear with me as I'm not the best at that, but ill do my best.
Old 12-25-2011, 10:00 AM   #10
hey guys i have updated the info. hope everyones ok with it, remember let me know of any info i have missed and ill add it accordingly please also remember to rate on items you have, or have had, so i can add ratings and let people know what you think of said item
Old 12-25-2011, 10:13 AM   #11
Great work! Very helpful thread, STUCK!!!
Merry Christmas Lordjasper1988.
Old 12-29-2011, 03:15 PM   #12
FYI - the BWD wideners work with stock wheels as well, the stock hexes go on the end of the widener and then you would use barrel nuts to mount. Works for both McRC and TT (must use the appropriate hexes for the stub axle).
Also, the wideners are available either with OR without the barrel nuts. Micro Widener Kit
Rockfrog is offline   Reply With Quote
Old 12-29-2011, 09:04 PM   #13
Great job on the thread!! I have a few rough numbers on the widths for the wheel spacer and axles. . ( stock MRC, Stub Axles & Wheel Hexes Mc4x4 LOSB1737, crawlerX spacers, dannelley rim mod, and miniqlo stock width). Let me know if you want the pics. Hope this helps!
All numbers are over to over with the beadlocks on.
Stock wheel width = 86mm
Mc4x4 losb 1737 = 92mm **** (cheap wheel extions and no plastic barrel nuts)
CrawlerX = 96mm ** (I've had nothing but bad luck with these. They Always strip out. Or there to tight or to loose)
Dannally wheel mod = 104mm ***** (if you are are going to run miniqlos this is the mod for you. I don't know what the link is tho)
MiniQlo stock axle width = 116mm
Madjones is offline   Reply With Quote
Old 12-30-2011, 08:21 AM   #14
Lightbulb Re: complete wheels and tires list!
thanks a lot guys ill add info when I'm next at laptop, can't do it from phone.
and those wheel bases... are they to the outside of the wheels? or from the insides?
Old 12-30-2011, 12:09 PM   #15
Hey the number are from outside to outside with beadlock on. I have pics of the widths if you want them?
Old 12-30-2011, 01:50 PM   #16
ok bud thanks and thanks for pics but i don't want info to be too cluttered, thanks again
Old 12-30-2011, 02:05 PM   #17
Just to add -
Mc4x4 losb 1737 and Danally wheel widening mod#1 = 110mm (without any other wideners and uses standard 2mm lock nuts)
Old 01-13-2012, 08:05 AM   #18
I've got an issue with the standard wheels.
After removing the foams and putting some BB-bullets as weights inside the tires I reattached the bead rings.
I then found out that the tire was still not locked to the rim. :(
Are the bead rings there only for show, so I have to glue the tires back?
Olle P is offline   Reply With Quote
Old 01-13-2012, 09:35 AM   #19
stock rims are fake beadlock and require tires to be glued back on
discgolferlee is offline   Reply With Quote
Old 01-18-2012, 02:45 PM   #20
hey guys ave updated the bwd micro vertex, bullet calliber changed from .22 to unknown as ive checked with the .22 round and theres plenty of wiggle room, if anyone knows the calliber please let me know
Tags
miclows, rc4wd, tires, wheels
complete wheels and tires list! - Similar Threads
Complete list of what you need to build up your AX-10 ecoli Axial AX-10 Scorpion 2 09-11-2007 03:57 PM
