Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Heritage Crawlers > Losi Micro-Rock Crawler
Thread: big block questions
Old 12-30-2011, 03:20 PM   #1
Default big block questions
ok so this might sound dumb but here it goes... i have the aluminum tranny and a 52t spur gear ordered and comin for my vinson quad project. also have 15t, 17t, 19t and a 21t pinion gears to choose from here. i want to get some speed out of this thing but still be able to crawl stuff with it ( i know oxymoron right?).
i want to big block this thing and i seen that alot of people use the 70t or 80t pn racing motor... has anyone tried the 50t?... is it too much for the parts to handle?... will it still be crawlable?
any advice would be greatly appreciated
brandonwalsh420 is offline   Reply With Quote
Old 12-31-2011, 12:58 PM   #2
Default Re: big block questions
Don't think so ... at least none posted here yet. Only one way to find out how it works, be the guinea pig.
Rockfrog is offline   Reply With Quote
Old 12-31-2011, 01:34 PM   #3
Midlife Crisis's Avatar
A 50 turn motor would most likely make it a turd, not enough torque to let it crawl. The problem would arise that you need to use the smallest pinion (for crawlability & torque) and not be able to because the 130 can will not allow the shaft close enough to the spur.
I have used and suggest the 70t for the best of both speed and grunt for your project. I recently upgraded to the 80t and it works good as well.
Midlife Crisis is offline   Reply With Quote
Old 12-31-2011, 05:48 PM   #4
Where do you purchase these motors from?
slimshaney is offline   Reply With Quote
Old 12-31-2011, 07:11 PM   #5
so maybe i should just use the 70t and try to gear it for the speed?... 70t is 10 bucks as opposed to the 50t which is 18 bucks... ill start my build thread on this soon... got some good pics and progress so far...
any other opinions would still be much appreciated since im still undecided on what to go with... might be in for being the first to try the 50t if no one else has yet...
big block questions - Similar Threads
C/K packin big block heat livewires HPI Wheely King 10 05-09-2011 07:37 PM
Big block swap hitman46mod HPI Wheely King 12 12-15-2007 07:29 AM
