01-05-2012, 07:57 PM | #1 |
Pebble Pounder Join Date: Dec 2009 Location: South OC
| RCMC wideners
Ok, the RCMC is coming together now. Running with a Losi 2S 650 mah pack that fits perfectly in the TVP behind the motor. HR shocks with cut springs for 50% droop and Slick Honey grease treatment. I have a set of Mickey Thompsons arriving tomorrow and I have HR bead locks wheels. I'm just not sure if they will fit with the existing hex and was wondering where to get wheel wideners, if needed. Thanks all!! |
01-05-2012, 08:10 PM | #2 |
RCC Addict Join Date: Oct 2009 Location: In the mancave...
| Re: RCMC wideners
They should fit. As far as wideners go, crawlerx has them and bwd has them. Though, I am not sure which will fit the HR rims...
01-05-2012, 08:28 PM | #3 |
Rock Crawler Join Date: Oct 2011 Location: Lexington
| Re: RCMC wideners
The HR rims use a hex, so either adapter will work. The Crawler X adapter is perfectly fine and is 1/3 the price of the BWD adapters.
01-05-2012, 09:09 PM | #4 |
Rock Crawler Join Date: Dec 2010 Location: Madison Co.,Ms.
| Re: RCMC wideners
I do not recommend BWD wideners for the RCMC, the barrel nuts are not compatible with the stub shafts (too small). That being said though, with the hr rims and the BWD wideners, you'll end up wider than the CrawlerX spacers. Reasons..... The hex of the wheel eats widener length with CX kit, while the hr wheels with the stock hex and BWD spacers allows the full length to be used for widening. I use BWD spacers and CX barrel nuts drilled out a bit to account for the RCMC thread size. The BWD kit is $29 for the spacers and nuts, spacers only cost $15. CX kit is $10, buy the BWD spacers and CrawlerX kit and mix n match to suit your needs for all around $30. Spare goods is always nice too. |
01-05-2012, 09:33 PM | #5 |
| Re: RCMC wideners
Thanks guys! I'll mount the MTs this weekend and hopefully won't need the widenes. I'll keep you posted!
RCMC wideners - Similar Threads | ||||
Wideners | cammok5 | Tamiya Clod Buster | 3 | 02-11-2009 12:21 AM |
wideners? | dynamaxxed | Tamiya Clod Buster | 2 | 12-01-2005 04:38 PM |
wideners ? | rock zombie | Tamiya Txt-1 and Juggernaut | 6 | 10-10-2005 09:43 AM |
