04-09-2012, 12:02 PM | #1 |
Newbie Join Date: Apr 2012 Location: Seattle
| Crawler Build Ideas
I recently picked up a used Micro Crawler and I'm starting to pick up parts for a build I'd like to do when I finish the Micro-T I'm currently working on. That build is posted up here: Ken Block Micro-T Build I've got one of Danally's DDT 110T Big Block System's on order. So with that as my power house I'd like to create a cool comp crawler style setup that's a really solid functional crawler. I originally wanted to go all out with 4WS and DIG but RC funds are low after the Micro-T build and I'm happy enough with the 2WS. I just want to put something together that crawls like a mofo with a comp style chassis. I also don't think i have the time for such a detailed build or to try a scaler right now anyway. So I'm looking for ideas on everything from parts to mods to do. I've already read the entire mod's thread here and elsewhere. I'm looking for some of the best performance mods to do. My build idea so far is this: -110T Predator motor with 17T pinion and 59T Spur -TMC Buggy Chassis Kit from CrawlerX (I like the look of that particular one) -RC4WD beadlock wheels with a set of either Interco Super Swamper tires or Mickey Thompson Baja Claw's. -Wheel wideners, longer drive shafts and maybe a Links and Driveline extension kit. Then toss some weight on the tires and go from there. Last edited by Black Rock; 04-09-2012 at 01:52 PM. Reason: Edit: Typos |
04-09-2012, 04:06 PM | #2 |
Quarry Creeper Join Date: Apr 2010 Location: virginia beach
Sounds like a great start. I had a crawler x buggy chassis when I had my first micro and it was awesome. Search krono7s on YouTube. I have a lil bid on there of mine if ur interested Sent from my cellular telebox |
04-10-2012, 01:10 AM | #3 |
Quarry Creeper Join Date: Apr 2011 Location: North Alabama
| Re: Crawler Build Ideas
sounds good so far.as for the tires I would say go with the mickeys. I sipped mine cutting every other lug (the small ones) off of the tires and they are downright mean.
04-10-2012, 11:46 AM | #4 |
Quarry Creeper Join Date: Jul 2011 Location: olympia
get the qlo tires... you wont regret it, especially with the big block in it |
04-10-2012, 05:14 PM | #5 |
You know, I got a pair of the Qlo's with the truck as one of the tires but I'm not a huge fan just yet. It crawls better with them on, but in the stock chassis form they are so stinking huge they seem too big for the build. They are also glued on the stock rims with the stock rim mod so it's going to be hard to get them off the truck to add weight to at least until I get some headlocks.
04-11-2012, 08:29 AM | #6 |
Quarry Creeper Join Date: Jun 2004 Location: Louisville
I've got two Micros. One is getting a Pinch chassis, a 100T motor, and defoamed stock tires with BBs for weighting. Might extend the wheels out, probably not. My other one is getting Super Swampers with wheel extenders, eventually a 100T motor (only bought one...) and a completely custom chassis setup I stole from a Clodbuster custom design called Silver Ghost. Gonna be awesome if I ever get it done. And I'd love to get my hands on the Red Cat Crawler for 4WS! |
04-12-2012, 09:52 AM | #7 |
Yah, the Redcat is cool though I never got a chance to drive it just yet. I nuked the PCB right off the bat wiring it up for a 2S lipo based on a bogus post. I later found the voltage rating of the board with maxxed out around 5 volts or so... The Redcat is way more burly than the Losi though, just not sure I'd use the electronics and go 4WS unless I can wire up the electronics to handle a 2S LiPo.
04-12-2012, 11:18 AM | #8 |
Rock Crawler Join Date: Nov 2008 Location: Nor*Cal Cameronpark
[QUOTE=Black Rock I nuked the PCB right off the bat wiring it up for a 2S lipo based on a bogus post. I later found the voltage rating of the board with maxxed out around 5 volts or so... .[/QUOTE] Hmm, you sure you soldered it up right? I run the redcat board in my 10x10 & it runs 3 servos for steering, all on 2s with no problems. I did burn up another redcat board with a faulty servo board on a diffrent project....Its weird though no smoke & no burnt smell but it just won't come back to life. |
04-12-2012, 11:52 AM | #9 |
Quarry Creeper Join Date: Sep 2009 Location: Bay Area
I don't really have anything to add but I just wanted to say your Micro-T build is badass! It would be really cool if you did a scaler build with your level of attention to detail... |
04-12-2012, 01:56 PM | #10 | |
| Re: Crawler Build Ideas Quote:
Thanks Raguvian! I'd love to do a scaler build, but I enjoy more of the mechanics and engineering of these guys right now so comp crawler is the plan. I don't think I have the patience for working on the modeling side of it right now anyway. Guys like Chevy55 do builds so far beyond what I've done, mine would look simple in comparison. | |
04-12-2012, 09:41 PM | #11 |
Rock Crawler Join Date: Oct 2011 Location: minot
freeze your qlo wheel/tire combo. the glue will snap when u try to peel it off. i LOVE mine with a widener and longer links! ill have a new build on here soon. |
04-13-2012, 12:46 AM | #12 |
That thing is sick man. I especially like the frame and axle guards. I'll try the freeze trick. I'd love to find a set of those billet works wheels too... I'm thinking a set of the Mickey Thompson tires would be fun if it doesnt work. |
04-13-2012, 05:48 PM | #13 |
RCC Addict Join Date: Oct 2009 Location: In the mancave...
if you get a new chassis such as the tmc buggy, your gonna want to extend your wheelbase. with an extended wheelbase and tires such as the mickeys, it doesnt look proportional. also, you'll need the extra diameter that the qlo's have. here;s mine at 5" on the nose. |
04-13-2012, 06:08 PM | #14 |
Ooooh, I love it! I was also thinking of using can material for some body panels too. So you think the QLo's are simply the way to go then with the comp crawler body and extended wheel base? What options have I got for extending the wheel base? I see the extender kits at CrawlerX and it looks like what you've got, but I'm not super familiar with crawlers and it's hard to know what other options there are for the micro scale RC's. |
04-13-2012, 08:33 PM | #15 |
RCC Addict Join Date: Jan 2011 Location: somewhere near Los Angeles...or a city looking thingy.
Elsewere, did you solder that chassis? Definitely extend the wheelbase, makes a big difference.
04-13-2012, 09:31 PM | #16 |
RCC Addict Join Date: Jun 2007 Location: MESA
Go with the qlo tires. With that motor and tire combo u can pull off stuff u won't beleive. |
04-14-2012, 09:18 AM | #17 | |
It kind of looks like they maybe got glued onto the rims a few times and are a bit more thrashed than I thought. Maybe I should just keep them on the stock rims for a set my buddies can try out. I'm currently trying to get about 3 of my buddies into RC's. I'd love to have another buddy want to bring a crawler along when we go out camping with the kids this summer. ;) | |
04-17-2012, 12:13 PM | #18 |
Alright! I'm stoked now. My Big Block Kit is on it's way along with the rest of my build parts. I've been getting daily runs on my "stock-ish" McRC and been making small adjustments here and there for huge performance improvements (removed shock springs, moved positions, added weight, cut plastic and moved ESC and battery). After enough runs I've finally decided that for this initial build the target is to make the best crawler I can with 2WS. So no dig, no 4WS, no lock outs. Just a well balanced crawler with a powerhouse motor and good geometry for sick crawling I'd love to do some mega 4WS beast with F/R dig, individual wheel lock out, etc but that may just be better for a bigger scale rig. Anyone know if you can bind a stock McRC ESC/Rx to another radio? I got mine used so no manual, and the ESC has been slightly modded already. What's that button on the top of it for? I'd love to bind the card if it's possible to my Spektrum DX2S since that thing has so much better control and tuning. I can see turning the throttle waaaay down and really digging in hard with the 59T spur and 110T motor. Creepin... |
Crawler Build Ideas - Similar Threads | ||||
Help with new build ideas | XxRockStar199xX | General Scale Talk | 2 | 11-01-2010 07:55 AM |
Need Ideas on a new build | TXJeeper1 | General Scale Talk | 5 | 10-11-2010 06:02 PM |
FIrst Build.. Need Ideas!!! | ztothej | Newbie General | 2 | 08-30-2010 05:26 PM |
Build Ideas | looneybin | Non Crawler RC's | 3 | 10-29-2009 08:55 AM |
