04-19-2012, 02:28 PM | #1 |
Newbie Join Date: Mar 2012 Location: Gatesville, TX
| Trail Trekker w/Blade TMC V2 setup questions..
Well just started in the crawler scene, but been into R/C for a while (2-TMAXX, 1- RC10T4, 1 - Mini-T, 1 - mCP, 1- mCPX that's on my work bench now...blah blah blah), but I have a few questions about the setup I have. I bought the Blade TMC V2 chassis the same day I bought my TT. The instructions and are based off a MRC. When I did this set up I had some major binding issues (TT being wider, longer, etc). I have flipped the shock tower everyway and tried every hole possable even drilling some new ones for another angle. I think I got it pretty good now, but just wondering if anyone else has the setup like me (TT w/Blade TMC V2 chassis) and what I could do better? Also on the very bottom on the chassis (Where the motor mounts) I can't seem to get it horizonal to save my life!! On the back I had to put the top links a little higher to releive some stress off the drive shaft for the angle was too sharp. It climbs a lot better now (Blade TMC V2 chassis, LiPo, wide wheel mods (Danally) and the boggers help a lot) then the stock setup. FYI Yes a HiTec servo is in the mail headed this way!! What can I do to make it better? |
04-19-2012, 03:29 PM | #2 |
| Trail Trekker w/Blade TMC V2 issues
Well I'm a noob to the crawler scence, but been in R/C for a while (2 - TMaxx, 1 - RC10T4, 1- Mini T, 1 - mCP, 1 - mCPX on the bench now....blah blah blah). Well I bought the TT, chassis, LiPo and Boggers all at the same time (After several weeks on here). Anyways I bought the Blade TMC V2 and put it together. The problem is the instruction are for the McRC and when I did this setup the TT was binded up everywhere. I flipped the shock tower everyway and used every hole I could to make things work. I got it to do pretty good, but just wondering what other have done with my setup and what I could do to make it better. Also the bottom piece (Where the motor mounts up to the chassis) I can't get it parallel to the table to save my life. I had to move the rear upper links up more to give the axles a better angle (Binding up) and I mounted the shocks opposite then the front. Like I said, just trying to see if I can do something better!! Thanks guys!! |
04-19-2012, 03:38 PM | #3 |
Pebble Pounder Join Date: Jan 2012 Location: ohio
| Re: Trail Trekker w/Blade TMC V2 issues
Check out my build went to tmc from the trekker Had no issues from what I could notice http://www.rccrawler.com/forum/losi-...cro-build.html |
04-20-2012, 06:57 PM | #4 |
Newbie Join Date: Aug 2010 Location: berkshires
It would appear that you need to mount the rear upper links 2 holes farther down on the chassis plate. You may have to mess with the shock mounting positions in the rear. Get more trekker brass ball mounts, they bind less.
03-09-2013, 11:22 AM | #5 |
Newbie Join Date: Jan 2013 Location: Summerland
Looks great! the only thing i can see that id upgrade would be the motor? lots of choices, i was happiest with a ddt predator 90 t. Great rig man
03-09-2013, 02:38 PM | #6 | |
Rock Crawler Join Date: Jan 2013 Location: Laguna Niguel
| Re: Trail Trekker w/Blade TMC V2 issues Quote:
I agree. It looks like your riding high in the suspension which is good for clearance but bad for COG. You could cut your springs to run a semi-droop setup to get the ride height down about 1/4-1/2" but, really, Its personal preference. | |
03-11-2013, 05:56 AM | #7 |
I joined the Band! Join Date: Jul 2011 Location: Philippines
what that is some crazy flex!!!!!!!! looks good...
11-18-2015, 08:12 AM | #8 |
Newbie Join Date: Nov 2015 Location: Cypress, Tx.
Awesome Looking rig! I am wanting to build one myself! I was wondering, what wheels are you using in your original post pictures with the TSL boggers on them??? Thanks! -Clint |
Trail Trekker w/Blade TMC V2 issues - Similar Threads | ||||
Trail Trekker w/Blade TMC V2 setup questions.. | Watsonst04 | Losi Micro-Rock Crawler | 0 | 04-19-2012 02:28 PM |
torsion bar tmc blade | elsewhere | Losi Micro-Rock Crawler | 6 | 11-16-2011 11:11 PM |
Project Blade TMC | Harkey013 | Micro Scale Rigs | 1 | 06-29-2011 03:03 PM |
Blade TMC Build question. | seven | Losi Micro-Rock Crawler | 5 | 04-11-2011 03:28 PM |
BLADE TMC chassis in the uk | ben'smicrocrawler | Losi Micro-Rock Crawler | 8 | 01-12-2011 10:06 AM |
