07-29-2012, 06:26 PM | #1 |
Rock Crawler Join Date: Apr 2012 Location: NewHampshire
| Micro sct or Foff?
this is prob the wrong forum to post this in but every one here is pretty knowledgeable. Any one have a micro sct brushless? im thinking of getting one or making a foff out of a redcat like some guys on here have done. i want a go fast rig. any insight from you guys would be awesome!
07-29-2012, 07:18 PM | #2 |
RCC Addict Join Date: Jun 2007 Location: MESA
| Re: Micro sct or Foff?
Most guys on here build one with Redcat axles, Losi tranny, and a good power-plant like a big block. I built one and it got parted out. It was fun but I lost interest. Search on here for foff and you will find some ideas. Good luck! |
07-29-2012, 07:46 PM | #3 |
Rock Crawler Join Date: Dec 2010 Location: Madison Co.,Ms.
I've built both. The FOFF rig had it's pros and cons as did the SCT build. All in all, the SCT dud better and was easier ti keep together. I
07-29-2012, 08:57 PM | #4 |
thanks guys! so far the sct is taking my eye, due to the fact its already running a brushless set up.
07-29-2012, 10:17 PM | #5 |
Rally wheels, crawler tires of your choice, soft springs/bladder mod, big spur/little pinion, and a low kv motor and you are FOFF'n! The Sct is light, basically a sled( smooth bottom) and durable as hell. Edit... BL isnt mandatory, mine runs a DDT 80t predator motor and melts pinions every run almost! Last edited by Midlife Crisis; 07-29-2012 at 10:20 PM. |
09-04-2012, 02:50 AM | #6 |
Newbie Join Date: Jan 2012 Location: USA
I have the brushless micro SCT! I actually really like it, it's a blast to drive. One issue though is sometimes the throttle doesn't respond. Often this is when you punch it, and you have to release and reapply to get the car to move. I'm not sure why it does this. I say this because I know throttle control is a crucial part of FOFF. I keep meaning to figure it out and fix it but haven't gotten around to it yet. Check out my review that I posted on RC Short Course. Lots of big, clear pictures. Losi Micro SCT Review - RCShortCourse.com Bulletin Board |
10-03-2012, 10:05 PM | #7 |
Newbie Join Date: Oct 2012 Location: North pole
i have the losi micro sct brushless with 2.4 .....its amazing the only thing you might want are aluminum lock nuts,progresive rate spring set(if you have peticular needs) and possibly a lipo i have the venom 250mah 7.4 volt 15c its made for it and well this baby goes
10-04-2012, 03:06 PM | #8 |
thx for the replys. i might just pick up a sumo like others have on here and throw the brushless system into it and make a foff.
10-31-2012, 10:48 AM | #9 |
RCC Addict Join Date: Jan 2009 Location: Bend
Sure hope you guys with Micro SCTs have a secret for me. I haven't taken mine outside but twice. Every time the tires hit anything other than the carpet, my swept garage floor, or the linoleum the pinion is gone! One little pebble killed that fancy little chromed brass pinion Losi gives you with the brushless model last time, and before that it got a piece of sand stuck in it that locked it up. I'm lucky to get 30 seconds outside before the damn thing sits lifeless...
10-31-2012, 04:51 PM | #10 |
Quarry Creeper Join Date: Aug 2011 Location: Sacramento
is that a sumo with a losi tranny?
11-01-2012, 06:07 PM | #11 |
Rock Crawler Join Date: May 2011 Location: Bama!
| Re: Micro sct or Foff? |
11-01-2012, 06:25 PM | #12 | |
| Re: Micro sct or Foff? Quote:
Losi Mini T Sand Paddle Rear Tires with Foam Inserts | eBay and nope thats how they go | |
11-02-2012, 05:03 PM | #13 |
Rock Crawler Join Date: Jan 2012 Location: Champlin, MN
not going to lie, they're backward. google the tire and you'll see they are all mounted so that they scoop as opposed to vee.
11-02-2012, 05:14 PM | #14 |
11-02-2012, 08:00 PM | #15 |
| Re: Micro sct or Foff? It's okay I've made the same mistakes with other tires.
11-02-2012, 09:50 PM | #16 |
Ha I was right just kidding but I was right.
11-03-2012, 12:10 AM | #17 |
Rock Crawler Join Date: Nov 2008 Location: Nor*Cal Cameronpark
| Re: Micro sct or Foff? Looks like you made the mistake again....Those tires perform better in the sand that way. The scoop's are rather tall & when spun around they dig bad, like your trying to leave the line & now your stuck in a hole on the line The way they are in the pic lets you float over the top of the sand like a magic carpet ride Ha smuggl1n you was wrong bro Last edited by chevy55; 11-03-2012 at 12:24 AM. |
11-03-2012, 12:34 AM | #18 | |
11-03-2012, 12:54 AM | #19 | |
Well I tried it both ways & this worked the best I think madjones would agree because in those pics up above, those are my tires on his rig during testing....I have seen plenty of sandrails run in the same direction at the dunes & they tear it up. & as soon as my b1r gets back from tekin mine will be running again.. Little Focker- Micro FOFF-Test Vid- I will get a recent pic with the bug body up soon.. Nice start on the mini I can't wait to see it throw'n rooooost, looks real mean! | |
11-03-2012, 08:46 AM | #20 | |
I'll agree about the dig issue however. guess it depends on how soft of sand your used to running. everything near me is gritty and thick. And i've never actually ran paddles myself yet. waiting till I can afford a Axial Wraith for my FoFF build. | |
Micro sct or Foff? - Similar Threads | ||||
Anyone have a Losi Micro SCT? | Hydro-Tank | Chit Chat | 11 | 01-09-2012 06:00 PM |
Micro sct Turned crawler | Ratboy99 | Losi Micro-Rock Crawler | 11 | 11-25-2010 09:04 PM |
micro sct wheels | jkurb00 | Losi Micro-Rock Crawler | 5 | 08-01-2010 10:13 AM |
