Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Heritage Crawlers > Losi Micro-Rock Crawler
Thread: Southern fried with westcoast flavor.
Old 12-18-2012, 10:30 AM   #21
Default Re: Southern fried with westcoast flavor.
Thanks fellas
Change of plans with the power plant went with a ezrun 18t can on the gearhead...All I can say is this combo was mind blowing on the bench testing with 3s....Plans are to drop in a quark 22a esc & run 4s, I can't wait for the first run!
chevy55 is offline   Reply With Quote
Old 12-18-2012, 12:46 PM   #22
The tube work is killer bro!!! 8 feet of brass is just nucking futs!!!!!!!
Madjones is offline   Reply With Quote
Old 12-18-2012, 06:04 PM   #23
Thanks Mr. Jones you know it will have about 12ft once its done & still be lighter than the Chevy body
Old 12-28-2012, 03:40 AM   #24
Its a roller
Old 12-28-2012, 05:28 AM   #25
afghafasfpwbnsasgfhbcxzv ... Sorry just cleaning the drool off my keyboard .... Amazing work ! What wheels are those ? They look badass !
rapttor is offline   Reply With Quote
Old 12-28-2012, 12:15 PM   #26
Thanks rapttor!
Wheels are from the losi micro rally car...
Team Losi LOSB1584 Tires Mounted Black Micro Rally | eBay
Old 12-28-2012, 02:20 PM   #27
how do the wheels work? pin drive or hex drive?
Mastah Kyler is offline   Reply With Quote
Old 12-28-2012, 05:22 PM   #28
Bad ass.
Once again, VIDEO!!!
elsewhere is offline   Reply With Quote
Old 12-30-2012, 12:55 PM   #29
this think give me alot idea!! you work is sick!!! 4s ? did you ever broke sumo axel parts??? I start a built with powerfull powerplan, i will order parts i think so!!!! but i never broke mlrc part!!!! i cant wait see wow you will do for the engine!!!
pliasticmudeller is offline   Reply With Quote
Old 01-15-2013, 04:11 PM   #30
Epoxied stock hex on the back side of the rally rim
Originally Posted by elsewhere View Post
Bad ass.
Thanks EW, I should have a test vid in the next few days!
Thanks pliasticmudeller, the sumo axle is very strong. I have been trying to destroy one with no luck yet
It took two weeks for my delrin to get here from PA So I got a little work done on the skid:
Everything sit'n low in the chassis
Old 01-15-2013, 04:17 PM   #31
You got details on the t-case setup? Is that motor gonna rip this thing apart?
89redranger is offline   Reply With Quote
Old 01-15-2013, 05:09 PM   #32
It is a sumo trans converted with some 1/8 rod & losi 12t pinion that was always the weak spot on my others:
That motor is a monster & on the 9.7:1 gear reduction with 4s it just might rip it apart
Old 01-15-2013, 06:36 PM   #33
Hey that's my vice... To bad I never thought of using it for milling
The skid looks amazing!!!!!!!!
Old 01-15-2013, 10:20 PM   #34
another question, did you bearing wheel hub??? mine look very lose!!! thank for the inpiration!!!
Old 01-15-2013, 11:37 PM   #35
This thing is CRAZY - more more more
doublej is offline   Reply With Quote
Old 01-16-2013, 06:38 PM   #36
I want it!
smuggl1n is offline   Reply With Quote
Old 01-17-2013, 11:32 PM   #37
Yes it is bro, glad you posted the cherokee vid or I would have never knew ya had it
I need to order some bearings right now just the brass bushings
Thanks bud! more pics below
Originally Posted by smuggl1n View Post
I want it!
You want to finish it off finding room for all the electronics is a real PIA...
I did get the driveshafts done & the skid reworked its a tight fit with that big motor & GR unit but it should work out....I hope to do a test run soon & yes it will be on video just incase it explodes
Old 01-18-2013, 12:19 AM   #38
Awaiting video......
Stance on her is perfect!
Old 03-10-2013, 05:08 PM   #39
Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update Update hey I think it's time for an update
Old 03-10-2013, 06:47 PM   #40
Interesting a wall of text
MattTheGenus is offline   Reply With Quote
Southern fried with westcoast flavor. - Similar Threads
2013 Westcoast Shootout rcjunky3 Past RCCA qualifiers 534 04-16-2014 01:59 PM
1911's in the delrin flavor Reflection EnRoute Berg 4 11-03-2009 08:49 PM
New Mountain Dew flavor RD400 Chit Chat 3 02-14-2006 11:35 PM
New Doritos Flavor TwistedXT Chit Chat 2 12-28-2005 01:48 PM
