01-13-2013, 10:37 PM | #1 |
Rock Stacker Join Date: Dec 2012 Location: canada
| FOFF Iceland style
this is my new built!!! sumo axel!!!! home made transmition!!! ? shock is comming!!front!!rear!!!fliping servo inside!! building transmition!! |
01-13-2013, 10:44 PM | #2 |
Rock Crawler Join Date: Oct 2011 Location: Lexington
| Re: FOFF Iceland style
Pics don't work!!!
01-13-2013, 10:50 PM | #3 |
i know , can i erase this post, and why is not apear ,just the link, sorry i'm new!!!!!
01-13-2013, 10:56 PM | #4 |
| Re: FOFF Iceland style |
01-13-2013, 11:01 PM | #5 |
badbadbad why the piuc dont apear????????????????????????????????????????????? ???????????????????????????????? i can't understand ?????????????????????????help me!!!!!
01-13-2013, 11:07 PM | #6 |
Rock Crawler Join Date: Nov 2008 Location: Nor*Cal Cameronpark
| Re: FOFF Iceland style Must have the IMG in front & rear of the code Like this>>> [IMG b_zps728691f8.jpg photo by tuyozr | Photobucket IMG] Awsome FOFF bud!!! Last edited by chevy55; 01-13-2013 at 11:14 PM. |
01-14-2013, 09:21 AM | #7 |
| Re: FOFF Iceland style that is th built of two speed transmition!!!! homemade center shaft |
01-14-2013, 09:27 AM | #8 |
finish product ,i try it very good speed in segond, and good wheel spin in 1st but for very rought terrain front rear axel setting with direction inside for better looking and 3 link suspention |
01-14-2013, 09:35 AM | #9 |
Rock Crawler Join Date: Jan 2012 Location: Champlin, MN
was it intentional that the direction on the tires are not all the same, and in fact are opposite from left to right?
01-14-2013, 10:01 AM | #10 |
this is just build tire ,better paddle is comming
01-16-2013, 07:13 AM | #11 |
and now i have to build stiffer shock,all aluminium with a pop rivet and 3/16 tubing!!!!they look amasing!!! they spring are inside , is gluted on a red line, ggreen is damping, yellow is for rebound and tork twist reduction!!! black is a storc pop rivet!!!!!!aand now on the truck!!!! nnow i work on a body panel!!! i try the truck, but i burn the stoct sumo esc, i have to buy onother or two!!! i like the 4 mode sterring, if some body have sugestion for electronic, compatible with red cat remote or not???mabee rock slide rx!!! but i need pretty ampered esc when i try it run crazy fast in 2nd gear!!!!!perfect for FOFF riding!!!! and in 1st gear run perfectly crawler speed with serious wheels spin!!! |
01-16-2013, 06:51 PM | #12 |
Quarry Creeper Join Date: Aug 2011 Location: Sacramento
how are the gears switched?
01-16-2013, 08:42 PM | #13 |
the gear will swicth manualy like a higth and low gear,i try it and is plenty playable in any geari have another mlc with 3 speed transmition with servo selector!!!!!! but for this is a light weight project !!! this is a link of my 3 speed transmition micro losi crawler 3 speed try the tranny - YouTube |
01-16-2013, 08:54 PM | #14 |
Rock Crawler Join Date: May 2011 Location: Bama!
You should build a dig tranny!!!
01-17-2013, 09:48 AM | #15 |
and now the finish product!!!i have plan hict other tire , but when i begin to work on it i see 1 has bigger then they 3 other the 4 come from the same place!!!! the ken block FOFF this is made from can!!!!!!!!! every thing on this truck is light weigth!!!! and super fast, yesterday my losi esc was smoking but is ok it run good just servo wire ground together!!! sugestion is welcome |
01-17-2013, 09:52 AM | #16 |
it's pretty easy to built a dig transmition for the micro losi axel!!!! if you want i canshow you wow!!!!!!!!!!!!!!!!!
01-17-2013, 04:11 PM | #17 |
and the tire for waiting something better!!!! homemade paddle vid is comming |
01-17-2013, 04:27 PM | #18 |
Rock Crawler Join Date: Apr 2012 Location: NewHampshire
pliasticmudeller this is epic! Good job! Your builds are sweet!
01-17-2013, 05:01 PM | #19 |
can you give a bit more depth on the trans? im interested in seeing more on how it works
01-19-2013, 08:19 AM | #20 |
i will do a post on transmition building!!!! 2 speed and dig for you !!!! 1st you have to find 2 speed gearing from nikko or any cheap and old rc!! |
LinkBacks (?)
LinkBack to this Thread: http://www.rccrawler.com/forum/losi-micro-rock-crawler/422732-foff-iceland-style.html | ||||
micro FOFF red cat sumo crawler axel 2 speed - YouTube | This thread | Refback | 02-22-2013 11:18 AM |
FOFF Iceland style - Similar Threads | ||||
car style foff | RootBreaker | Formula Offroad | 101 | 05-28-2015 06:40 AM |
Slash 4x4 Foff Style Build, need tips | stompjrkz400 | Formula Offroad | 5 | 03-10-2012 06:12 PM |
Foff, UK style | igbandy | Formula Offroad | 7 | 08-07-2011 02:45 PM |
Driving on the Water...BWD FOFF Style! | billet works | Videos! | 17 | 04-25-2011 01:28 PM |
