05-02-2013, 08:20 AM | #1 |
Pebble Pounder Join Date: May 2007 Location: Titletown
| Micro Cralwer Wheels/Tires
Im building a scaller that needs smaller tires than 1.55, I am using the Losi MRC axles, these use a 12mm Hex. RC4wd has a Beadlock whell for the Micro but it says 7mm hex? Regaurdless anyone know if anyone sells a hex or another way to convert Losi Micro wheels and tires (aftermarket or Market) to fit the Mini axle? 12mm Hex? what I have seen the Micro doesnt even use hex, but I have never looked at one in person or checked out the wheel. I figured the guys that work and play with the Micro's might have an idea before I ask up in Scale. Gonna try to take a look at my local Honny shop today if they have a micro, but at the same time its a small shop so I doubt they do. Thanks. Dave |
05-02-2013, 08:30 AM | #2 |
Rock Crawler Join Date: Oct 2004 Location: The thumb
| Re: Micro Cralwer Wheels/Tires
The micro does in fact use a hex and pin just like the mini only smaller as you found out. Not sure that a micro wheel is what your looking for as they are 1" diameter.. A venom minigiant (also called the A-tech Bison) also used hexes (not sure the size) and the wheels were larger than the micro but smaller than 1.55. I have some minigiant wheels here somewhere if you'd like me to measure them... |
05-02-2013, 09:32 AM | #3 |
RCC Addict Join Date: Jan 2009 Location: Bend
On micro wheels and tires a mini would have around 1/4-3/8" clearance under the diffs. Way too small. You may have to mod a set of Mini T wheels, or possibly a set from a Mini 8ight. I believe they are around a 1 1/4" wheel.
05-02-2013, 12:00 PM | #4 |
Rock Crawler Join Date: Nov 2008 Location: Nor*Cal Cameronpark
What would be the ideal tire dia. for your project? You might want to look into a set of traxxas mini slash wheels & tires, they take a 12mm hex & are 2 1/2 inches tall. Last edited by chevy55; 05-02-2013 at 02:10 PM. |
Micro Cralwer Wheels/Tires - Similar Threads | ||||
Micro RTR Cralwer | Krazee DD | General Crawlers | 3 | 01-03-2011 08:12 PM |
