Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Heritage Crawlers > Losi Micro-Rock Crawler
Thread: My brushless trail trekker
Old 04-20-2014, 09:02 PM   #41
Default Re: My brushless trail trekker
Originally Posted by anuthabubba View Post
I would take those huge stickers off. Maybe put a few small equipped with/sponsor stickers in a couple of spots.
That's what I want to do. How do you suggest taking them off i tried peeling them off but they just rip and leave a sticky residue.
dirtbikekid is offline   Reply With Quote
Old 04-20-2014, 09:06 PM   #42
Heat is your friend.
Crank is offline   Reply With Quote
Old 04-20-2014, 09:57 PM   #43
Cover the area with a paper towel and wet it with Goo Gone. Let it soak a few minutes. Wipe off with dry paper towel. Might have to repeat step one. That stuff dries out my hands so you might want to wear gloves.
anuthabubba is offline   Reply With Quote
Old 04-20-2014, 10:28 PM   #44
ok ill try that. would walmart carry that?
Old 04-20-2014, 10:38 PM   #45
Should carry it. It's a small bottle so it can be missed on the shelf amongst all the other larger ones.
Old 04-21-2014, 03:44 AM   #46
Sticker residue, unlike glue, can only work against a clean an solid surface. So wipe your fingers on natty rag. Take the stickers off and wipe the residue using firm pressure with your fingers. It takes all but 5 minutes and doesn't require any chemicals.
mathcanbefun is offline   Reply With Quote
Old 06-08-2014, 10:05 AM   #47
Update!!! Got a new motor for my trekker. it is a 1811 2900kv 12g motor (I think its a 12g). correct me if im wrong but i believe this is the biggest motor i have seen in a trekker/micro that is brushless. heres a link to the motor Radio Control Planes, Helicopters, Cars, Boats, FPV and Quadcopters - Hobbyking* .
heres the motor
it wasnt that hard to put in just had to do the same mods as i did to my previous 5g motor. here is a size comparison
It fit good on motor mount. fits the same as the 5g.
Here it is in the trekker. Only thing i had to do was grind the chassis a little because it was rubbing.
I am liking the motor a lot. For gearing i went with the biggest of the 3 stock pinions and stock spur. I did have to drill the hole in the pinion because the motor has a bigger shaft. I love the wheel speed to! Even tho its a higher kv an bigger pinion then with my older setup i still have a good low end crawling to and it doesn't cog much at all.
Old 06-09-2014, 06:33 PM   #48
Here is a video of the speed and slowness of my new motor
Brushless losi trail trekker new motor - YouTube
Old 06-28-2014, 08:50 PM   #49
made a video today. this is with my new motor. my batterie was half dead(drove it like an hour the day before) with a fully charged baterie it has a little more speed. let me know what you guys think!
brushless losi trail trekker dirt crawling - YouTube
Old 06-29-2014, 06:12 PM   #50
Love the control shown in the video. Great set up
Loganradd is offline   Reply With Quote
Old 06-30-2014, 06:05 AM   #51
I joined the Band!
what is the mod?
RootBreaker is offline   Reply With Quote
Old 06-30-2014, 11:10 AM   #52
Originally Posted by RootBreaker View Post
what is the mod?
Just cutting the 2 side brackets and drilling the new hole in the motor mount. Look at post #1 and #47. If you need a better explanation and pictures i could do that.
Old 07-02-2014, 09:32 PM   #53
finally got around to getting the stickers off and it looks alot better. here are some pics of it now
i hopefully will get a video this weekend of it and might get that up by the next weekend.
Old 07-19-2015, 07:12 AM   #54
I just got a used trekker and finished putting the 5g motor in last night. Very easy except I had to glue the pinion on. Guess it stretched from the stock motor. Great write up, I'm going to run 3s 1300 packs of they fit. Hopefully the motor can take it. I saw you did pulling tests on 3s with good result.
Haulingram82 is offline   Reply With Quote
Old 06-20-2016, 10:30 PM   #55
So after running the 2900kv 12g motor for awhile im kinda leaning towards putting the 5g back in. dont get me wrong i love the 12g but its not quiet the style of driving i want to do. the 5g has less cog and better at slow speeds. the 12g is better for faster style of crawling, like sand or dirt hill climbs. not so much technical rock crawling.
Old 06-22-2016, 10:28 AM   #56
Brushless motors are good for this too. Mind your rev's...
Fungi is offline   Reply With Quote
Old 06-22-2016, 11:50 AM   #57
Call that one gold dust lol.
Sent from my SAMSUNG-SGH-I337 using Tapatalk
MidniteMarauder is offline   Reply With Quote
Old 06-22-2016, 06:37 PM   #58
Attachment 344684
i have never had that happen in the 5 years ive been running my micro lol. pack your axles full of marine grease and that shouldnt happen.
Old 08-21-2016, 05:10 PM   #59
Noticed this is a little older thread? Is the motor still running?
bignheavy1007 is offline   Reply With Quote
Old 09-11-2016, 06:50 PM   #60
oh yes running like a champ haha havent had any problems
My brushless trail trekker - Similar Threads
Brushless micro trail trekker? Bigblockrockwells Newbie General 6 10-01-2013 03:05 PM
trail trekker brushless?? akrcguy Losi Micro-Rock Crawler 4 10-29-2012 03:17 PM
Losi Trail Trekker Gravedigger Brushless Video Included stomper4x4.com Losi Micro-Rock Crawler 9 02-22-2012 10:06 AM
dustinbleh's *BRUSHLESS* Losi Micro 4x4 Trail Trekker Build! dustinbleh Losi Micro-Rock Crawler 63 08-01-2011 03:15 PM
Trail Trekker RCTRUX Losi Micro-Rock Crawler 6 05-24-2011 10:42 AM
