11-07-2014, 05:32 PM | #1 |
Newbie Join Date: Nov 2012 Location: Torrington
| Lipo help.
Probably a dumb question but here it goes. I have an Ares ethos quadracopter that uses a 300mah 1s lipo (3.7v) that I wanted to try using with my micro crawler. They use the same Losi battery connector. I played it safe and checked the plug with a multi meter and the polarity seems to be different... Easy enough, right? Switch the polarity and I should be good to go? So I grabbed some new connectors and a short length of wire to make a splice that switches the polarity (so I can easily switch between both RC's. With that said, when I went to test, the ESC won't turn on, and after a few seconds being connected the battery starts to heat up and voltage drops to nothing. I was under the impression of I had the polarity the same I "should" be fine? My apologies, I'm electrically challenged. Thanks |
11-07-2014, 06:44 PM | #2 |
RCC Addict Join Date: Jan 2011 Location: Forest Floor
| Re: Lipo help.
What you described is a short circuit, where the battery wires were connected directly together. Perhaps a possible wiring error or loose connector in the polarity reverse switch? Supplying 3.7v to a device capable of accepting 4.8v - 7.2v will not cause damage by itself. Something else had to cause the rapid current draw from the battery. The ESC is probably just fine which is the important part. |
11-07-2014, 07:08 PM | #3 |
Quarry Creeper Join Date: Oct 2014 Location: East
| Re: Lipo help.
A picture of the setup would help a lot
11-28-2014, 05:57 PM | #4 |
| Re: Lipo help.
Well, I still don't know where the short circuit was, but I cut the heat shrink off and re-soldered the wire, added new heat shrink and all is well.
