01-14-2015, 11:55 AM | #1 |
Pebble Pounder Join Date: Mar 2008 Location: sherbrooke
| HR lockout problem
just got my HR lock out for the rear axel and put them on my trailtrecker and i cant put back my wheel nut there is not enough thread left on the shaft they send with the kit. anyone know the solution cuz seen some trailtrecker with them. the kit i purchased is mcc2208 thanks
01-14-2015, 12:02 PM | #2 |
| Re: HR lockout problem
i think i found the solution on my son micro crawler the hex are not the same let me know if this is the solution thanks
01-14-2015, 12:21 PM | #3 |
RCC Addict Join Date: Jan 2011 Location: Forest Floor
The lockouts were designed for the Micro Rock Crawler, but the Trekker uses longer axle stubs so they won't work.
01-14-2015, 01:55 PM | #4 |
They do work but i need to put micro crawler hex that are thinner that the one on the trecker. By doing that it narrow the track by approx. 5mm. That good it will fit beter under my 1/20 toytoy pickup body. Will post pics soon
01-23-2015, 09:45 PM | #5 |
Quarry Creeper Join Date: Jan 2015 Location: Alcoa
Curious about using these on a trekker as well. Is there a good way to run these without narrowing the rear with the crawler hexs? Maybe stock crawler hexs with a widener kit designed for micro crawlers on the rear? I searched about this and bumped an old thread before noticing this one, sorry! |
01-24-2015, 05:20 PM | #6 |
you could narow the rear with the hr straith locker and the front with losi micro crawler parts and buy some wheels from fungi with offset
01-24-2015, 07:46 PM | #7 |
Thanks for the help. I just got some aluminum beadlock wheels last week so I'm probably going to run those for now. (Wish I found this place earlier!) Ive got the hr axle lockout on the way, if I switch my hexs to crawler ones (losb1723) and run a set of wideners for crawlers, that would keep the offset the same or similar? Thanks again!
01-25-2015, 06:25 AM | #8 |
could be a good solution lets us know what set of widener you find i would be interested also i do want to keep my hr strait axles
HR lockout problem - Similar Threads | ||||
axle lockout help | richierm | Venom Creeper | 8 | 09-13-2011 01:11 PM |
need lockout | roy 2 | Duratrax Cliff Climber | 4 | 10-06-2009 04:35 PM |
Rear lockout | Leeroy | HPI Wheely King | 4 | 06-24-2008 02:13 PM |
Tlt lockout | revoster | Newbie General | 2 | 06-20-2006 08:35 AM |
