Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Heritage Crawlers > Losi Micro-Rock Crawler
Thread: I need a motor pic
Old 04-22-2017, 09:01 PM   #1
Default I need a motor pic
Working on a micro crawler and it is basically a pile of parts. There aren't any leads coming off the motor. Can someone post a closeup pic of their stock setup so I can get the correct wires soldered to the correct terminals. Thanks.
moyoman202 is offline   Reply With Quote
Old 04-22-2017, 11:53 PM   #2
Default Re: I need a motor pic
Wire it up either way. If it runs backwards and you're triggering forwards just flip the THROTTLE switch on the transmitter.
Brake Weight is offline   Reply With Quote
Old 04-23-2017, 07:17 AM   #3
There are 4 different places that I could solder a wire to the back of this motor.
Old 04-23-2017, 07:29 AM   #4
Pic of motor? Mine had just two tabs on it.
Old 04-23-2017, 07:46 AM   #5
I guess it's 3 places not 4.
Old 04-23-2017, 06:38 PM   #6
dieselmudder is offline   Reply With Quote
I need a motor pic - Similar Threads
a Stupid motor question to pic your brains with gm0688 Axial XR10 3 12-08-2010 10:08 PM
RCP Crawlers 2.2 Motor Driven Axle Assembly **See a Pic** Post Your Comments Rockpiledriver RCP Crawlers 48 12-28-2007 02:09 PM
just finished building the new motor for the SS...(pic) STANG KILLA SS Chit Chat 16 07-21-2007 05:45 AM
