Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > Losi Mini-Rock Crawler
Thread: LiPo Battery for the MRC?
Old 09-11-2008, 10:06 PM   #1
Question LiPo Battery for the MRC?
Hi, I'm new here and new to crawling. I had a Tamiya Hot Shot as a kid about 20 years ago and now I'm sporting a TRX Stampede VXL and my new little Losi MRC.
I was just browsing the maxamps site and noticed they have a battery for the MRC. However, this is my first Losi product and I cannot seem to figure out what plug to have pre-installed. When I first got the truck I immediately purchased a TRX->Tamiya->Losi adapter to use with my Hyperion charger, but there was no mention of what the Losi connector type was.
So I guess my question is which connector do I choose so I don't have to alter the connector on the ESC (I'm terrible at that stuff). I just want the same connector that the stock battery had on it. http://www.maxamps.com/proddetail.ph...4-Pack&cat=182 is where the pack is found.
Another question I have is will a better battery give this steering servo a bit more torque? If not I think that is the next piece I'll be replacing. Out of the box it seems a bit weak to me. If you wanted to be extra helpful you could toss an idea for a new servo because I haven't a clue where to begin. Thanks!
dextermeth is offline   Reply With Quote
Old 09-11-2008, 11:33 PM   #2
MPI still refers to the connector Losi uses as the HPI plug since it was first used in HPI's Micro RS4.
BJoe is offline   Reply With Quote
Old 09-11-2008, 11:34 PM   #3
Just switch out everything to Deans connectors and be done with it.
TooSlow is offline   Reply With Quote
Old 09-11-2008, 11:56 PM   #4
Is that the Micro 1/18 Scale Plug? I don't see an HPI in the pull down list.
Thanks
Old 09-12-2008, 12:01 AM   #5
Could be Dex. I'm planning on using the pack from a Parkzone J3 Cub in mine.
Do you use the same screen name on the Traxxas forum?
I go by bjoehandley over there.
Old 09-12-2008, 07:53 AM   #6
Yeap thats me. :-P
I'm just trying to keep it simple, no changing of adapters etc etc. I'm gonna check out that pack. The reason I have been sticking with the maxamps is I have a hyperion tapped balancer on the charger. Just trying to stay simple and consistent so my wife can charge it without issue (it's hers)
Old 09-12-2008, 03:54 PM   #7
In case anyone is wondering, the correct choice was Micro 1/18 Scale Plug. Seems entirely too obvious in retrospect. Hopefully Jason at maxamps got it right.
