09-23-2008, 03:42 AM | #1 |
Newbie Join Date: May 2008 Location: Volcano
| Losi MRC Steering issue
This may be normal and I may be paranoid, but, when I steer my new Losi MRC all the way in either direction, it makes the front end bounce. It seems to get better if I set the sterring rate back to the middle but then it doesn't turn well at all (not unlike a bus). Anyone else have this issue? Its most noticable if I turn the steering rate to the max and hold the truck in my hand while accelerating and turning all the way at the same time. The servo and axle vibrates real bad. I can;t tell if the axle is hitting something while the wheels are turned or what. Maybe this is just the way it is made and I am asking too much. Any ideas?? Thanks!! |
09-23-2008, 07:39 AM | #2 | |
Pebble Pounder Join Date: Jul 2006 Location: Universal City
it could be the dogbones are binding in the cups. it's not good for it but it's normal. if you really want to have that extra steering you can grind out the dogbone. just be careful. it won't be as strong that way. | |
09-23-2008, 09:15 AM | #3 |
Quarry Creeper Join Date: Sep 2008 Location: Castro Valley
I only had that issue when I changed my tires. They were overall a 1/2 inch taller and would hit the lower links at full steer.
