10-02-2008, 09:48 PM | #1 |
Quarry Creeper Join Date: Jul 2007 Location: Sierra Foothills
| Axle Gear Set Question
Looking at the parts list it appears to me that the Mini LST and the Mini Crawler use the same gears for the front and rear axles, except that the Mini Crawler uses locker plates. Does anybody know if the axle gears are interchangeable? P/N is LOSB0941 according to the Mini Crawler manual. Any input would be appreciated. Thank you
10-02-2008, 11:48 PM | #2 |
Sr. Product Developer Join Date: May 2005 Location: Fontana
Yes they are, the Ring and Pinion are the same from the Mini LST 2l. The original Mini LST had plastic gears. You will use everything from these diffs, with the exception of the spider gears, the lockers go in place of that. Hope this helps, Rich |
10-03-2008, 01:01 AM | #3 |
RCC Addict Join Date: Apr 2006 Location: On Da' Shelf
That's good to know. Mahalo's for the info Rich! |
10-03-2008, 08:37 AM | #4 |
| Thank You Rich
Rich, thank you for the OFFICIAL input, and most of all for this great little truck. I have some much 1/10th crawler stuff it is almost embarrassing but now in the process of selling it off to concentrate on the 1/18th. I already have two of the minis and hope to get one more for parts. I am working on one for a display piece only and will send you a photo soon. I wish Losi would consider a 1/24th crawler that would be the perfect size in my mind. Hopefully you can consider that in the future. Thank yu again. Mick
10-03-2008, 09:44 AM | #5 |
Rock Crawler Join Date: Jan 2007 Location: monson
10-03-2008, 10:38 PM | #6 |
Rock Crawler Join Date: Jan 2007 Location: San Clemente, CA.
LOSI, 1/24th 1/24th 1/24th 1/24th!!!!!!!!!!!!!!!!
