10-22-2008, 11:40 PM | #1 |
Pebble Pounder Join Date: Oct 2008 Location: Belcamp
| shocks
im running full droop all the way around, and it seems to be working very well except my belly clearance? any suggestions? thanks guys |
10-23-2008, 01:16 AM | #2 |
RCC Addict Join Date: Apr 2006 Location: On Da' Shelf
Use some fuel tubing on the shock shafts outside of the shock body to gain some center clearance, or you could put them inside the shock on top of the piston.
10-23-2008, 04:20 AM | #3 |
Quarry Creeper Join Date: Feb 2005 Location: Indy-Westside
Swap the shocks out for some Mini T, Mini LST, or similar shocks and run them sprung. The stock shocks are longer than those mentioned. That'll lower your CG (compared to stock sprung) but still give you some center GC.
10-23-2008, 09:59 AM | #4 | |
Rock Crawler Join Date: Apr 2008 Location: Albany
I have been looking at shocks for the minis. The fronts are shorter then the rears. Does Losi sell the fronts only. Evan | |
