10-25-2008, 12:54 PM | #1 |
Pebble Pounder Join Date: Oct 2008 Location: Belcamp
| Bent lowers?
hey guys i just linked the rear and was wondering how you bend the lower links to be even? thanks |
10-25-2008, 01:08 PM | #2 |
Quarry Creeper Join Date: Jul 2007 Location: south jersey
i line 2 up in a vise and then bend them together
10-26-2008, 06:47 PM | #3 |
makes sense lol thanks |
10-26-2008, 09:47 PM | #4 |
Rock Stacker Join Date: Sep 2008 Location: Under the bed
Are these bent links? http://www.hot-racing.com/?partnumber=MRC553L01&c=444 I'll definitely be picking that up if it is. |
10-26-2008, 10:01 PM | #5 |
i dont see a pic?
10-27-2008, 03:43 PM | #6 |
I just assumed the 30 deg was referring to the links being bent/
10-28-2008, 12:33 AM | #7 |
then yes you are correct |
10-28-2008, 08:41 AM | #8 |
Yeah maybe, TRX calls their caster blocks 30 degress and I dunno what the heck they are talking about. They just look like casters too me. And for all I know the 30 degress is the angle between the upper 3 link portion of the Losi. Helpful ay |
10-28-2008, 08:43 PM | #9 |
true, i just made my own link and bent lowers. its easy |
10-30-2008, 09:46 AM | #10 |
Rock Crawler Join Date: Oct 2008 Location: Florida
I put a 4/40 threaded rod thru a piece of aluminum tubing and screwed Dubro 4/40 ends to the thread sandwiching the aluminum tube. I then put them on the vice and bent them at the same time. It only cost about $7 bucks. I don't know if it's the best way but it worked well for me.
10-30-2008, 11:36 AM | #11 |
Pebble Pounder Join Date: Aug 2008 Location: orlando
yeah i did the aluminum tube with threaded rod i used traxxas ends i used a tube bender from harbor freight to make the bends -- you can get one for 5-7 bucks discount auto also sells the tube benders well worth it .... |
10-30-2008, 08:43 PM | #12 |
yup i treaded 3mm grub rod into the aluminum and reused the eyelets from the lowers, and used t-maxx ends for my custom uppers |
11-01-2008, 03:21 PM | #13 |
Quarry Creeper Join Date: Oct 2008 Location: Crawlin' in NorCal!
aluminum is all good but your better off using stainless steel. The stainless is going to allow the truck to slide a little easier when it gets hung up where as the aluminum will scratch and bind up a little more. |
11-02-2008, 01:38 AM | #14 |
RCC Addict Join Date: May 2005 Location: Auburn, WA
| I really don't think it's much of an issue on a truck as light as these are, at least not enough to justify the added expense of stainless.
11-02-2008, 07:34 PM | #15 |
i agree, these trucks are no were near heavy enough. |
